Hi All:
I know this is a common failure on these vehicles but I didn't think it would be time to replace these again yet.
I bought the Mountaineer in my sig back in 2015 and shortly after we got it, replaced both front wheel bearings. The experience wasn't too bad considering the vehicle came from the south, but still, I bought the $100+ each Timken hub/bearing assemblies as I didn't want to do it twice. The car had 112k on it at the time. It now has about 154k and is exhibiting the same symptoms as before:
-Grinding feeling coming through the pedal and steering wheen when the steering wheel is even slightly pushed off of where it's centering
-Noise corresponding with above grinding feeling
-No discernible play in bearings with the vehicle jacked up.
I'm expecting to hear that Timken bearings aren't all they're cracked up to be anymore and if I do have to do this again I will likely buy the cheap $49 bearings if I'm going to have to replace them every 3 years anyway.
Anyone have any input on what else to check or where else to look?
Anyone else have lackluster experience with Timken?
