123 registered members (2_Tall_Mitchell, 77GrandPrix, Al, 14Accent, 4WD, 87sammy, 12 invisible),
1,994
guests, and 29
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,550
Posts5,137,862
Members70,092
Most Online3,589 Nov 2nd, 2019
Filing down a square surface
#4857188
09/01/18 12:00 PM
buck91
OP
OP
Posts: 2,957 |
So, maybe not strictly a tooltime topic but it does relate to USING tools so I thought it was appropriate.
Anyways, doing some tinkering at home and I need to file down some aluminum surfaces to get everything toleranced. Basically, they are cylinders 19.5mm diameter x 13mm tall which I need to take 3mm off the height of. Managed to get one done pretty good using my eye and my hand on a big [censored] file and cleaning up with a ceramic sharpening stone. Had a very hard time keeping the working surface square and even. I suspect that due to imperfect pressure using my hands to hold everything it tended to file/grind/abrade unevenly. I also tried using my grinder on the flat side of the wheel which was much quicker and easier.
Any suggestions for keeping everything square? Its too small to mount up, and I can't really see a jig design that would work...
2011 F150 4x4 5.0L 1996 Mustang GT 5spd/ragtop
Re: Filing down a square surface
[Re: buck91]
#4857221
09/01/18 12:59 PM
spasm3
Posts: 10,685 |
If you start off square, sandpaper on glass. I've done aluminum intakes and an oil pump housing by sliding them on sandpaper on top of a thick sheet of glass.
13 elantra 81k 5w30 synpwr 03 chevy avalanche 83k synpwr 5w30 17 mazda cx-5 17000 miles synpwr 5w30
[Re: buck91]
#4857225
09/01/18 01:04 PM
sleddriver
Posts: 4,838 |
I've done similar using a Taig lathe.
1998 Volvo V70 T5 228,880 mi. Original Owner. M1 10W-30 HM "It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
[Re: buck91]
#4857291
09/01/18 03:47 PM
Traction
Posts: 1,320 |
I will wrap things with wide masking tape, and if the ends line up overlapping, then it's pretty square.
Certified Tire Service Instructor since 2009 50 Chevy Fire Truck 13 Tahoe Pursuit 97 C5 Corvette 00 BMW M Roadster 02 Camry 12 Camry 81 Camaro 55 Chevy C4
[Re: buck91]
#4857339
09/01/18 05:15 PM
Trav
Posts: 22,653 |
For stuff like this a surface grinder is the correct tool but most people don't have one in the garage. A small stationary belt sander with a fine belt works well too if you have one. You could probably do it with a orbital sander by holding the piece against it and moving it around slowly, start with 180 grit until its almost there than switch to a fine grade. A pic of what you want to do would help.
[Re: buck91]
#4857353
09/01/18 05:35 PM
AZjeff
Posts: 4,354 |
If you can scribe a line that you can file or sand to it will help, similar to the masking tape suggestion.
86 Samurai 1.3 leftovers 14 RAV4 2.5 5W-20 PP 18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
[Re: buck91]
#4857405
09/01/18 06:41 PM
Silk
Posts: 5,344 |
Keep moving the cyl around, or move around the work yourself. Use a draw file technique - grab that barstar* like a pair of handlebars and push away from your body.
1987 BMW R65 - Penrite VTwin 20-50 2005 Nissan Expert - 5W-30 Castrol Edge 1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
