Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
Pennzoil Ultra on Sale
by Nyati. 07/16/19 04:39 PM
Not All Mid-Grade Blended At the Pump
by RayCJ. 07/16/19 04:30 PM
Determining if car battery has much life left
by paulri. 07/16/19 02:47 PM
kohker oil recomendation
by 1978elcamino. 07/16/19 02:44 PM
Rear Diff Seal Leak?
by Pike51. 07/16/19 02:31 PM
Using synthetic to clean a crankcase
by NavyVet88. 07/16/19 02:26 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
89 registered members (4WD, AndyB, AdditiveOCD, ammolab, alcyon, 2015_PSD, 10 invisible), 1,952 guests, and 24 spiders.
Topics291,968
Posts5,014,207
Members68,681
Most Online2,967
Mar 10th, 2019
Filing down a square surface #4857188
09/01/18 01:00 PM
09/01/18 01:00 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
So, maybe not strictly a tooltime topic but it does relate to USING tools so I thought it was appropriate.
Anyways, doing some tinkering at home and I need to file down some aluminum surfaces to get everything toleranced. Basically, they are cylinders 19.5mm diameter x 13mm tall which I need to take 3mm off the height of. Managed to get one done pretty good using my eye and my hand on a big [censored] file and cleaning up with a ceramic sharpening stone. Had a very hard time keeping the working surface square and even. I suspect that due to imperfect pressure using my hands to hold everything it tended to file/grind/abrade unevenly. I also tried using my grinder on the flat side of the wheel which was much quicker and easier.
Any suggestions for keeping everything square? Its too small to mount up, and I can't really see a jig design that would work...
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Filing down a square surface [Re: buck91] #4857221
09/01/18 01:59 PM
09/01/18 01:59 PM
out there
spasm3 Online content
spasm3  Online Content
out there
If you start off square, sandpaper on glass. I've done aluminum intakes and an oil pump housing by sliding them on sandpaper on top of a thick sheet of glass.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Filing down a square surface [Re: buck91] #4857225
09/01/18 02:04 PM
09/01/18 02:04 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
I've done similar using a Taig lathe.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Filing down a square surface [Re: buck91] #4857291
09/01/18 04:47 PM
09/01/18 04:47 PM
iowa
Traction Offline
Traction  Offline
iowa
I will wrap things with wide masking tape, and if the ends line up overlapping, then it's pretty square.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Filing down a square surface [Re: buck91] #4857339
09/01/18 06:15 PM
09/01/18 06:15 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
For stuff like this a surface grinder is the correct tool but most people don't have one in the garage. A small stationary belt sander with a fine belt works well too if you have one.
You could probably do it with a orbital sander by holding the piece against it and moving it around slowly, start with 180 grit until its almost there than switch to a fine grade. A pic of what you want to do would help.
Re: Filing down a square surface [Re: buck91] #4857353
09/01/18 06:35 PM
09/01/18 06:35 PM
PV Az @ 5000'
AZjeff Online content
AZjeff  Online Content
PV Az @ 5000'
If you can scribe a line that you can file or sand to it will help, similar to the masking tape suggestion.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Filing down a square surface [Re: buck91] #4857405
09/01/18 07:41 PM
09/01/18 07:41 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Keep moving the cyl around, or move around the work yourself. Use a draw file technique - grab that barstar* like a pair of handlebars and push away from your body.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
