Originally Posted By: wallyuwl
I would try a few more drain and fills a week or two apart, and find out what the codes are. If it needs more than $500-$600 of work then get rid of it for something else. You could also look into a junk yard transmission if you can find one with clean fluid.
+1
I would try a different fluid to see if it helps. Specifically, I would try Maxlife, based on my recent experience with it in my Cad.
Edit: check valvoline recommendation first, but they recommend for at least some fords.
+1
