Originally Posted By: bubbatime
What are you trying to accomplish? You have to have a defined mission before ANYONE can even start to answer your questions.
You mentioned 18 inch barrel and buckshot and larger bird shot loads, so perhaps you are talking about home defense? Or maybe predator control on a farm?
40 yards isn't home defense, so I'm taking a wild guess that this is for predator control?
You probably should be aware of a shot-cup called Flight Control wad. Hornady sells the EXACT same thing, but they call it a Versa-Tite wad. These specialized waddings are designed to keep the shot pellets together over much longer distances. If you are shooting buckshot over long distances (40 yards) then you need to use a Flight control or Versatite wad.
Most 18 inch barrels have a cylinder or modified choke. These are ideal for Flight control or versatite.
If your gun has replaceable chokes, such as full, you do NOT want to use flight control or versatite wads with a full choke gun. Your pattern will actually be worse. Full choke is for regular shotgun shells that lack versatite wads.
Report back exactly what you are trying to accomplish and perhaps we can give you a better, more informed response.
I believe I may have in the past already acknowledged and complimented your unusually astute observational skills.
"40 yards isn't home defense, so I'm taking a wild guess that this is for predator control?"
You got it, this is not for home defense, most likely this is going to be for feral dogs. These aren't strays, these are serious predators with bad intent, no fear, sometimes (not always) coming out of heavy cover at fairly close range, they generally know we're there before we know they are there, and often there's more than one. I don't want to depend upon a handgun, and if they are at the distance that a carbine could be used, they really aren't a threat. I want something that takes the initiative out of their attack.
The reason I asked the question the way I did is my sense is there is some size shot that is going to provide an optimally sized pattern with an adequate amount of energy at a certain range plus or minus a few yards.
Slug barrel, doesn't have replaceable chokes.I will look at flight control and versalite.
As always I appreciate your participation and advice.
