Synthetic 5W30 D1/Gen2 vs. Synthetic 10W30 ?
by ChrisD46. 07/20/19 07:00 PM
ECOGARD X4612 NEW FILTER CUT OPEN
by 53' Stude. 07/20/19 06:48 PM
Show me your dinner
by 53' Stude. 07/20/19 05:52 PM
Shelf life of Gumout fuel injector cleaner
by pentode. 07/20/19 05:24 PM
Started a big job on the Carrera
by rooflessVW. 07/20/19 05:17 PM
Taco Bell Cantina
by vavavroom. 07/20/19 05:13 PM
TEC SELECT T 4612 CUT OPEN
by 53' Stude. 07/20/19 05:01 PM
2012 Ford 3.0 V6 Kendall GT-1 5W-20 6488 mi
by AITG. 07/20/19 04:37 PM
Replaced All Signaling Bulbs At One Time
by RayCJ. 07/20/19 04:21 PM
Cheryl's New She Shed
by MolaKule. 07/20/19 04:16 PM
Thread sealant for bolts holding diff cover.
by Snagglefoot. 07/20/19 03:30 PM
Meguiars Hybrid Ceramic
by rdevans89. 07/20/19 03:02 PM
2015 Mitsubishi Outlander GT trans. filter
by Kira. 07/20/19 03:02 PM
Could microglass/synthetic media filters harm engines?
by Deontologist. 07/20/19 01:47 PM
A/C problems 2016 Nissan Quest.
by JTK. 07/20/19 01:37 PM
change once a year regimen
by alex_at. 07/20/19 01:34 PM
What would you like to do in the future?
by Red91. 07/20/19 12:45 PM
Pulling timing for high IAT
by LAGA. 07/20/19 11:55 AM
Roadtripp, Denali376, GoldDot40, Dtn2, Bonebender
68717 Registered Users
94 registered members (53' Stude, 08z06, 007, AdditiveOCD, AlienBug, 9 invisible), 2,022 guests, and 29 spiders.
Topics292,159
Posts5,017,829
Members68,717
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Oil suggestion, towing and consumption. #4850875
08/25/18 07:07 PM
08/25/18 07:07 PM
GA
Silver Offline OP
Silver  Offline OP
GA
4.2L Chevy Trailblazer I6.
148,000 miles.
Manual says 5w30.
I ran PP 5w30 in this truck until I noticed it started using 1-2 quarts between 10k oci's. I then went to PP high mileage 5w30. I've already used 3 quarts at 7000 into oci. I drive aggressively with frequent high rpm's and tow around 5500 lbs 15 miles 2 or 3 times per month. No leaks at all.
I wonder with the towing of about 5500 lbs and consumption if I should use a thicker oil?
May not be relevant but my timing chain tensioner just failed in some manner after a couple WOT bursts. I'm having it replaced and the truck won't see quite as much high rpm driving!
Thanks
Mike
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850881
08/25/18 07:12 PM
08/25/18 07:12 PM
AL
two4spooky Offline
two4spooky  Offline
AL
Considering your location(GA) I would say yes, use a heavier oil like 10w30 or xw40. I am sure someone will be along to say a 0w20 will be better.
'18 Toyota 4Runner ORP 4.0l - 3k
'03 Honda Accord EX 2.4l - 140k
'97 Toyota Tacoma 4x4 3.4l - 237k
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850892
08/25/18 07:28 PM
08/25/18 07:28 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Wouldnít hurt to use a thicker oil while towing. Iím running 5w30 but have 5w40 Mobil 1 TDT tucked away for the spring oil change.
If you want the job done right......do it yourself.
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850898
08/25/18 07:35 PM
08/25/18 07:35 PM
Long Isle ...
KnicksGiants Offline
Long Isle ...
148,000 miles.
Manual says 5w30.
Thanks
Mike
Personally I would have chose a Toyota. It just might be that the vehicle is near the end, sorry to say. You may want to try their Ultra oil. Or an oil loss additive. Not to bash any car makers, but it's hard for me to stray from the Japanese brands precisely bc of problems like this. Not to say Toyota and Hondas never have problems.
At this point, you need a judgement call on how much you want spend on a car with 150k miles. Can you live with adding oil, or do you want something new, or a motor replacement etc.
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850900
08/25/18 07:37 PM
08/25/18 07:37 PM
MT
jongies3 Offline
jongies3  Offline
MT
Try 10W-30 or maybe even 0W-40 wouldn't hurt. Pennzoil Ultra or M1 European formula are great choices, same with German Castrol.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: PYB 10W-30, FRAM COR3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850904
08/25/18 07:40 PM
08/25/18 07:40 PM
California
VeryNoisyPoet Offline
California
1-2 quarts in 10k for an engine of that age used in severe service is not bad at all. 4 quarts in 10k (based on what it's using so far) is getting high. M1 high mileage 10w-30 is on the thick end of that viscosity range and has higher HTHS than most 10w-30 oils, so would be a good choice for towing in hotter climates. An Xw-40 would also be a good option.
Does the vehicle have an oil cooler? High RPM and high load in warm temps can roast oil pretty fast. Ever notice the oil pressure warning light flicker or pressure gauge drop down below 10 psi at idle after a hard towing run?
Timing chain tensioner was probably a fluke unless they are known to fail at high RPM when old.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Oil suggestion, towing and consumption. [Re: KnicksGiants] #4850911
08/25/18 07:48 PM
08/25/18 07:48 PM
GA
Silver Offline OP
Silver  Offline OP
GA
Heh, most definitely as Honda and Toyota both had class actions filed against them for consumption.
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850913
08/25/18 07:50 PM
08/25/18 07:50 PM
NH
supton Offline
supton  Offline
NH
Doubt the tensioner is anything but a fluke, not related to rpm.
IMO, if you're driving it hard, just live with the consumption. Maybe change to a 5k OCI and run something you don't mind burning a bit of.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 152k, ours
1999 Toyota Camry LE, 2.2L/4AT, 208k, his
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850916
08/25/18 07:51 PM
08/25/18 07:51 PM
NH
supton Offline
supton  Offline
NH
And rust, and sludge.
Re: Oil suggestion, towing and consumption. [Re: VeryNoisyPoet] #4850920
08/25/18 07:53 PM
08/25/18 07:53 PM
GA
Silver Offline OP
Silver  Offline OP
GA
No oil cooler. Never noticed the oil guage drop but that doesn't mean it doesn't. I'll watch it next time. Honestly the tow trip is short so it may not get all that hot. I'll look at the viscosities of high mileage oils and try a 10w30. If I recall correctly, the new Castrol Titanium oils are pretty thick too.
Would I have to worry about a thicker oil not flowing well enough at high rpm's when I drive "irresponsibly"?
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850921
08/25/18 07:53 PM
08/25/18 07:53 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Unless it was a diesel, I wouldn't put that many miles on an OCI while towing. The most 3,500 OCI's.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Oil suggestion, towing and consumption. [Re: FermeLaPorte] #4850924
08/25/18 07:55 PM
08/25/18 07:55 PM
GA
Silver Offline OP
Silver  Offline OP
GA
Thanks. I really didn't think much of it as it's a short trip once a week, but perhaps it is worth adjusting for.
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850940
08/25/18 08:07 PM
08/25/18 08:07 PM
California
California
Under high load (mountain grade with full load) the oil in my car rises from 200F to 250F in just a couple minutes, though oil cooler stabilizes it around there. It can rise faster than you think.
Also, it it an actual pressure gauge, or an idiot gauge that just reads in the middle using the pressure switch?
The difference between a 30 wt and 40 wt at operating temp is tiny compared to the difference between cold oil and hot oil. Or even warm oil and hot oil. You want the oil film to be robust enough at high RPM and load to protect cylinder walls and bearings.
"Use yah blinkah!"
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850941
08/25/18 08:07 PM
08/25/18 08:07 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Replace the PCV valve with an OEM part. You may have a weak spring thatís allowing oil mist through.
You can try adding a can of BG EPR to see if you have some stuck oil control rings.
Try M1 HM 10w-30 as suggested above, and if consumption does not slow I would switch to whatever 10w-30 happens to be on sale at Walmart. No point in using the expensive stuff if itís just being burnt and replaced with fresh.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Oil suggestion, towing and consumption. [Re: Silver] #4850948
08/25/18 08:11 PM
08/25/18 08:11 PM
Yellowbrick Rd(KS)SemiRetired
Marco620 Offline
Marco620  Offline
VW drinks oil like crazy.
15' Civic 1.8 i-vtec 254,000 mi Redline 5/0w20, BP transmax cvt fluid & Archoil9100
Tornado Chaser Extraordinar!
Son of a Navy Corpsman. Support vets!
Page 1 of 4 1 2 3 4
