New Fave way to remove snow from vehicles
by JC1 - 11/12/19 08:19 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
How often to drive a second car.
by SouthDakotaDad - 11/12/19 03:48 PM
Manufacturers, Bypasses & Large Sumps
by ad244 - 11/12/19 03:23 PM
Samsung DeX for PC
by dogememe - 11/12/19 03:19 PM
2008 Acura TL Timing Belt/Component Kit
by BAJA_05 - 11/12/19 02:06 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
117 registered members (2003f7, 14Accent, Aichiguy, 2015_PSD, 92saturnsl2, Aero540T, 11 invisible), 2,066 guests, and 19 spiders.
Topics297,336
Posts5,113,306
Members69,840
Most Online3,589
Nov 2nd, 2019
72K miles on Amsoil using Bypass - PentaStar V6 3.6L #4849641 08/24/18 10:38 AM
StevieC Offline OP
'18 Caravan - 45k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849652 08/24/18 10:52 AM
T
thescreensavers Offline
T
Little confused from the paperwork shown,
Jan 2nd Lube time was 1894 Mi and miles on car was 62944mi
So the oil sample is about 12k miles?
Also how many filter changes where there? The filter is stated to take 1qt.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849655 08/24/18 10:58 AM
StevieC Offline OP
Yeah something is up with those dates/mileages for sure... I didn't notice that.
The bypass filtration filters should be changed every 2 years I think. It will remove 1 or so quarts from the system when these are changed so top-off oil is required. Also depends on which filter he is using they have 3 different sized ones available.
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849657 08/24/18 11:00 AM
SirTanon Offline
popcorn This should be an interesting discussion.
I'm not liking those copper numbers AT ALL. Aluminum is starting to go up too. Also, I'm seeing a notable depletion in the additive metals. If I were in that situation, I'd be changing now.
2013 Nissan Altima SV - 2.5 liter/CVT - 123,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 69,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849665 08/24/18 11:12 AM
StevieC Offline OP
Same here on the changing it part.
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849728 08/24/18 12:30 PM
Donald Offline
Some of the differences in samples are due to time of the year the sample was taken.
Copper is not good. Too high. Oil cooler? Copper lines for the bypass setup?
At the end of the day a UOA costs more especially from OAI than an oil change.
2015 Ford F250 w/Powerstroke
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: thescreensavers] #4849799 08/24/18 01:47 PM
Speak2Mountain Offline
good Lord
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: thescreensavers] #4849806 08/24/18 01:57 PM
Z
ZeeOSix Offline
Z
I don't hear exactly how many quarts of new oil was installed over the 60K miles on this oil. He said 1 qt at the bypass filter change, but did he add any along the way from oil consumption. The description info on the YouTube video says:
"In this video I talk about my 2013 Town and Country minivan in which I started using Amsoil oil in it at 18,000 miles(I've been a dealer for 18+ years). I have since installed a bypass filter unit and have begun to you use oil analysis for extended drain intervals. This will be my second oil analysis that I have submitted and I talk about the results and how I am able to continue to drive on the same oil I put in almost 60,000 miles ago."
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849807 08/24/18 01:59 PM
G
gregk24 Offline
G
I don't see the appeal of doing this, just put fresh oil and a filter annually! It's not that expensive!
2012 Honda Accord EX-L K24z3
59,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
51,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: gregk24] #4849813 08/24/18 02:06 PM
Agree. Sounds like somebody just likes to brag about going X miles on y oil/filter
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849858 08/24/18 03:27 PM
StevieC Offline OP
If I were to use Bypass I would never go to this limit but use it to extend an oil change to the point it makes synthetic cost and the extra filter costs worth it over the price of a conventional oil change reaping the benefit of really clean oil all the time and the convenience of a lot longer OCI's. Those that run it this far it just ridiculous.
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849877 08/24/18 03:54 PM
A
Audios Offline
A
Amazing to see oil hold up that long. My head would explode if I went that far on it though haha.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4849914 08/24/18 04:48 PM
J
Johnny2Bad Offline
J
Only reason to use bypass filtration ... which I once considered, and am not averse to using in the future ... is to remove sub-10~5 micron contaminants, which does not seem necessary given modern bearing tolerances and wear patterns.
It's not cost-effective for regular "cleaning" of oil or to extend OCIs because modern synthetics mitiatate that need today. Was possibly more useful prior to the fuel injected / computer controlled / conventional only oil era roughly pre-1990. Especially in the 1950's and 1960's when they were first becoming popular (if you read Popular Mechanics and bought in on the backpage ads).
Still, if I were building up a new engine and could amortize the cost over the whole build, I'd still consider it. The rationale there would be then it would allow a freer flowing full flow oil filter, which would pass more oil pressure. I know that is somewhat weak as far as justification goes, but it's not harmful, which is not something you can say for most oil "treatments".
Not Amsol though, too expensive consumables when a case of single-ply Kimberley-Clark commercial rolls are a buck apiece.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: Johnny2Bad] #4850061 08/24/18 08:08 PM
Z
ZeeOSix Offline
Z
Those sized particles can still do damage on journal bearings that run as tight as 0.0007~0.0010" (18 to 25 microns) clearance. The running MOFT oil wedge will be even smaller than the clearance spec. Any particles that can get sucked into the MOFT wedge of the bearing can do potential damage.
Re: 72K miles on Amsoil using Bypass - PentaStar V6 3.6L [Re: StevieC] #4850152 08/24/18 09:31 PM
Donald Offline
I think doing a bypass oil filter and UOAs only make sense for engines with large oil sumps, ie., diesel engines.
A bypass does nothing for the additives, they deplete at the same rate whether you have a bypass filter or not.
The oil alone for my Powerstroke (Rotella T6) is close to $90. Add a Ford filter and over $100. This is just buying oil at Walmart and filters at Amazon
