I'm investigating again what coolant to use in my Escort, i've found this which looks appealing.
https://www.repsol.com/imagenes/global/en/max_quality_pure_coolant_antifreeze_tcm14-25160.pdf
" It is free of amines,
nitrites and phosphates"
So it's free from the typical Inorganic additives found in European IAT coolants, except Silicates, which seems appealing as Silicates are for aluminium and my engine has everything but the block made of aluminium.
This to me sounds like a HOAT right? aren't most HOAT's, OAT's with silicates in Europe, and OAT's with Phosphates in Japan?
It doesn't say specifically on the datasheet wether it's IAT, HOAT or OAT, however it meets VW TL744 C, which is a G11 spec, it's also blue like most / all G11s
So we know it's G11, however isn't G11 supposed to be a full IAT, with nitrates, phosphates, amines etc etc included?
I'm debating wether to use this, or a G12++ Si-OAT made by the same company.
