Does anyone here have a disabled child?
by SLO_Town. 07/20/19 07:08 PM
Synthetic 5W30 D1/Gen2 vs. Synthetic 10W30 ?
by ChrisD46. 07/20/19 07:00 PM
ECOGARD X4612 NEW FILTER CUT OPEN
by 53' Stude. 07/20/19 06:48 PM
Show me your dinner
by 53' Stude. 07/20/19 05:52 PM
Shelf life of Gumout fuel injector cleaner
by pentode. 07/20/19 05:24 PM
Started a big job on the Carrera
by rooflessVW. 07/20/19 05:17 PM
Taco Bell Cantina
by vavavroom. 07/20/19 05:13 PM
TEC SELECT T 4612 CUT OPEN
by 53' Stude. 07/20/19 05:01 PM
2012 Ford 3.0 V6 Kendall GT-1 5W-20 6488 mi
by AITG. 07/20/19 04:37 PM
Replaced All Signaling Bulbs At One Time
by RayCJ. 07/20/19 04:21 PM
Cheryl's New She Shed
by MolaKule. 07/20/19 04:16 PM
Thread sealant for bolts holding diff cover.
by Snagglefoot. 07/20/19 03:30 PM
Meguiars Hybrid Ceramic
by rdevans89. 07/20/19 03:02 PM
2015 Mitsubishi Outlander GT trans. filter
by Kira. 07/20/19 03:02 PM
Could microglass/synthetic media filters harm engines?
by Deontologist. 07/20/19 01:47 PM
A/C problems 2016 Nissan Quest.
by JTK. 07/20/19 01:37 PM
change once a year regimen
by alex_at. 07/20/19 01:34 PM
What would you like to do in the future?
by Red91. 07/20/19 12:45 PM
Roadtripp, Denali376, GoldDot40, Dtn2, Bonebender
68717 Registered Users
104 registered members (4WD, 53' Stude, 08z06, AdditiveOCD, 2004tdigls, 007, 5 invisible), 1,938 guests, and 26 spiders.
Topics292,161
Posts5,017,849
Members68,717
Most Online2,967
Mar 10th, 2019
Fuel efficiency related to engine size #4847999
08/22/18 07:41 PM
08/22/18 07:41 PM
Indiana
5AcresAndAFool Offline OP
Indiana
So there was a discussion at work and it was said that the 5.4L F150s get better fuel economy than the 4.6L in a truck with identical equipment aside from engines. Similar remarks have been noted on the silverado line.
So I looked on the EPA fuel economy website and the 2008 f150 with the 4.2l V-6 and the 4.6L V-8 indeed get the same fuel mileage in testing, the 5.4 either gets slightly below or the same as the other two depending on trim package, which maybe has something to do with rear axle ratio or something.
I know there are many other examples of this across the automotive landscape.
I have always understood that engines are most efficient at low rpm and wide throttle openings. Now the econominder gauges you would sometimes see in the 1970s or 1980s, which was basically a glorified vacuum gauge would tell you otherwise.
Anyway it seems that its very simple, a gallon of gas has a certain amount of energy in it and it takes a certain amount of energy to move a vehicle that weighs xxxx.xx lbs down the road. This is assuming that the different engines have a similar volumetric efficiency.
Now take certain vehicles such as a 2008 V-6 Camry and it definitely swills more fuel than the I-4, these seem to be the anomalies though.
So why would a smaller engine not save fuel. That is my question.
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848021
08/22/18 08:07 PM
08/22/18 08:07 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I dont know the math behind it, but I think its mostly to do with torque curves. The faster you spin the engine the more fuel it drinks. I hope one of our resident gear heads can chime in because Id love to understand this.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848022
08/22/18 08:07 PM
08/22/18 08:07 PM
PA
d00df00d Online content
d00df00d  Online Content
PA
Any engine will get its best fuel economy within a certain range of load and RPM. Sometimes, a larger engine has a range that lines up nicely with a certain usage pattern, whereas a smaller engine would end up out of that range with the same usage (e.g. it has to rev too high). In that case, the larger engine could well be more efficient.
Some small engines are just really high-strung, which makes them inherently less efficient than they could be. An engine like that often doesn't get any better fuel economy than a bigger one that didn't have every last hp/L squeezed out of it. I think Honda S2000 vs. Corvette is an extreme example of that.
Many engines are optimized too much for the EPA test cycle (or the equivalent in another market) and not enough for real-world conditions. AFAIK that was the problem with the Smart Fortwo and the Ecoboost F150. If you drove them exactly within the parameters of the EPA test cycle, you got the EPA-rated fuel economy. But if you strayed just a little bit outside those parameters, mpg dropped like a rock.
Lastly, as you suggested, final drive could explain everything. If the bigger engine gets a taller final drive, that might boost its mpg accordingly.
Tangential: weight means a lot for mpg at low speeds, but aero drag counts for a lot otherwise.
2008 BMW M3 Sedan 6MT
Re: Fuel efficiency related to engine size [Re: d00df00d] #4848036
08/22/18 08:31 PM
08/22/18 08:31 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
Originally Posted By: d00df00d
... Tangential: weight means a lot for mpg at low speeds, but aero drag counts for a lot otherwise.
"Weight means a lot for mpg" at both low and high speeds whenever braking, consequent acceleration, and hill climbing are involved. Not as much in steady level travel, when aero drag normally dominates.
2011 Toyota Prius now at 101K
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848046
08/22/18 08:47 PM
08/22/18 08:47 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
If the gearing was the same on both engines and you drove them at the same throttle openings and shift points, the smaller engine would be always more efficient, but a bit slower.
Typically the smaller engine gets run at higher rpms and if it also has a shorter top gear it could get worse mileage just going 60 down the highway. Watching the CVT work with instantaneous mileage displayed on the Outback really opened my eyes on how important keeping the rpms low is for good mileage. Basically you get your best mileage running the lowest rpm possible for the load. The Outback will run with the TC locked at 1100 rpm in town if you just need 5-8% throttle opening to maintain your speed or even accelerate a bit.
I suspect I could get the Outback up to 33-35mpg on my commute equal to my Focus, just because it can be driven at so much lower rpms all the time.
07 Focus ZXW, 5spd manual, 245km M1 5W30
18 Outback 2.5 CVT 35km 0W20
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848065
08/22/18 09:07 PM
08/22/18 09:07 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
My 3.5 Litre V6 in the Highlander gets better fuel economy than my Dodge Journey with the 2.4 Litre 4 cylinder did. Because it keeps the RPM much lower most of the time thanks to having 4 more speeds in the transmission.
'18 Caravan - 40k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Fuel efficiency related to engine size [Re: d00df00d] #4848075
08/22/18 09:15 PM
08/22/18 09:15 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
Any engine will get its best fuel economy within a certain range of load and RPM. Sometimes, a larger engine has a range that lines up nicely with a certain usage pattern, whereas a smaller engine would end up out of that range with the same usage (e.g. it has to rev too high). In that case, the larger engine could well be more efficient. ...
Yes, that right. The usage pattern is critical to whether a larger engine will be more efficient or not. In general, engines are most efficient at moderately high load and moderate speed.
Also in general and other things being equal, a larger engine is theoretically more efficient than a smaller one if both are working equally hard in proportion to size. That's because the larger one's combustion chamber has less surface area in proportion to displacement. Therefore, it has proportionately lower friction and lower heat losses to the metal surfaces.
Re: Fuel efficiency related to engine size [Re: CR94] #4848078
08/22/18 09:24 PM
08/22/18 09:24 PM
ME
eljefino Offline
eljefino  Offline
ME
Originally Posted By: CR94
[quote=d00df00d]
True, and this is why utility vehicles like potato chip trucks have ~3-liter, 4 cyl turbo diesels. The Jag V12 was a disappointment due to so much internal friction.
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848082
08/22/18 09:26 PM
08/22/18 09:26 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Trucks are heavy & have the aerodynamics of a barn, You can't compare them to lighter, low slung sedans with better aerodynamics.
2001 Chevy Camaro L92/4L80E
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848131
08/22/18 10:10 PM
08/22/18 10:10 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
It's all about weight they are having to move and at rpm
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848213
08/22/18 11:37 PM
08/22/18 11:37 PM
Long Isle ...
KnicksGiants Offline
Long Isle ...
I remember watching a Top Gear episode where they had a really cheap, small economy car go "fast" around a race track, and it was followed by a super car. I think the eco was 3 cylinders. Afterwards, he said the eco ate more gas than the super car, so you're better off with a bigger engine.
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848250
08/23/18 01:39 AM
08/23/18 01:39 AM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
I think it's worth mentioning thermal efficiency here. A cylinder with twice the volume won't have twice the surface area. The less surface area in the cylinder, the less of both frictional losses you have (ring area vs. piston surface area) and thermal losses (hot gas, distance from cylinder wall to center, dissipation of heat into the surrounding metal vs. doing work)
2005 Tahoe - 140k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Fuel efficiency related to engine size [Re: IndyIan] #4848342
08/23/18 06:24 AM
08/23/18 06:24 AM
Atlanta,GA
BMWTurboDzl Offline
BMWTurboDzl  Offline
Atlanta,GA
Agree, My current ride is programmed with a driving mode called "eco pro" and the rpm/gear is exactly as you describe. My only quip is that I loose responsiveness because I don't have any excess torque (probably why I should have a diesel, but the goshdarn emissions systems are weak and the I4 variant is currently prone to catching fire).
435i
Re: Fuel efficiency related to engine size [Re: KnicksGiants] #4848392
08/23/18 07:17 AM
08/23/18 07:17 AM
PA
PA
It was a Prius driving as fast as it could around the test track, and an E90 M3 following it. At those speeds, the Prius was obviously way outside its comfort zone and likely exhausted its battery pack, but the M3 was barely awake.
Not exactly a realistic scenario, but it does illustrate the point.
Re: Fuel efficiency related to engine size [Re: 5AcresAndAFool] #4848529
08/23/18 09:48 AM
08/23/18 09:48 AM
Southeast
meep Offline
meep  Offline
Southeast
Lots of good, and very partial answers above. I looked into this years ago, and found that the dynamics of all of the above answers and more all work together. Look up the bore and stroke of those two engines. If the gearing ratio and transmission ratios are the same, pay attention to the stroke.
Yes, smaller displacement engines are generally more efficient. BUT, longer stroke engines, in my armchair research, yield better MPG in comparison of several different vehicles with engine options. This of course, is also by itself a partial answer, but it was quite consistent what I found when I looked into it before.
2018 F150
2015 crv (wifey!)
