Originally Posted By: artbuc
Originally Posted By: jeepman3071
Many of the aftermarket self adjusters are lousy and don't work correctly. Mine are the opposite and don't do anything, so I just manually adjust them a few clicks once a year.
They are supposed to adjust when in reverse and applying the brakes (like backing out of a driveway). Gunk and build up (corrosion) also contributes to them not working. I'd pull the drums off and make sure the shoes still have material left and that everything is clean and moves.
Ok, but what would make the brakes grab when you first hit the brakes in reverse? The self adjuster engages and forces shoe against drum momentarily and then shoes center?
I've had many Jeeps with those exact rear brakes. A few TJs, a YJ and my current XJ. After a damp night, they will ALWAYS grab on first press. After driving them for 14+ years, I just take off with the parking brake on.
They are NOT adjusted with the parking brake. You need to hit the brakes while going backwards to get the auto adjusters working.
Second - A few years back, I had a topic ranting on how awful drum brakes were. I could not, for the life of me, get the drum brakes on my Cherokee to work. I'd tried numerous hardware kits, to no avail. Nothing would work and they would back off and stop working completely within 4 or 5 applications of the brake pedal.
I did some research and found that most hardware kits come with the wrong length cable. After discovering that, I went out and bought the ONLY hardware kit on the market --- unfortunately, I can't remember which one that was --- that had the right length cable. Since that point, the rear brakes have worked great on my Cherokee.
I was really, really considering swapping rear discs to it. But really wanted to avoid it since it's infrequently driven which would mean I'd be dealing with hung calipers. Plus, there was no easy way to get the parking brake working.
Honestly, once I figured out which hardware kit to buy with the right auto adjuster cable, I have no desire to switch this to rear brakes. My parking brake works fine pointed up or down hill. And even with 33x12.5 tires, it stops great. I can even lock up the rear brakes with 33'' tires.
Since my rant a few years ago, I have really gained an appreciation for them. I go in mud a lot, which wears out the shoes. So usually every 10 months or so I have to throw a new set of shoes on. No big deal. I can change the shoes in 20 minutes on each side with the cheapest rockauto shoes.
