Originally Posted By: Lynniecee
Hopefully it will loosen up with more miles but was suspecting some tight clearances with 65 lbs oil pressure with hot engine and was wondering if 5w-20 oil might flow better and work better than 10w-30.
At what RPM with hot oil is the oil pressure at 65 PSI?
Using 5W-20 isn't going to make you have more oil volume flow unless the oil pump is in pressure relief with xXW-30, which I doubt it is. The positive displacement oil pump will just give a hair more oil pressure with xW-30 than with xW-20. I'd run a good non-synthetic 5W-30 and break the engine in relatively easy for the first 1000 miles. 5W-30 will pretty much work in about anything on the road for normal street driving.
~65psi is stock relief pressure for an SBF IIRC.
If so, then sounds like the pump is in relief at idle with hot oil ... went back and saw that he said oil pressure was 65 PSI at idle in the first post. I didn't see anywhere that he said the oil pump was aftermarket (ie, higher output than stock).
I would have to think that the re-builders should know what the rods and crank bearings measured out at.
Yet it seems, as per his post that they don't
I'd wager it's an HV pump, as that's pretty common to "upgrade" with rebuilds in both SBF and SBC scenes, despite the complete lack of need for them, at least in the SBF.
