Originally Posted by Garak
None of that matters with the now ubiquitous ULSD. The only reason to stay with something "older" would be when lacking ULSD, and even then, one could just shorten OCIs. If I recall correctly, the OCIs on those 7.3s were extremely short anyhow, so all of this is moot. Should guys with early 5.9 L 12 valve Cummins engines be seeking CF oil, too?
It's all backwards compatible. Ford likes a panic every couple decades. I remember their panic in the first year or two of the 7.3 L Powerstroke over foaming.
How does the contamination of the engine oil from injector lubricants compare to the contamination from Low Sulfur Diesel (1993) and can the current formulation of Diesel engine oils resist the oil contamination from injector lubricants?
When I write injector lubricants, I refer to Stanadyne injector lubricants, for example. What about contamination from 2-cycle oil being used as an injector lubricant?
