Originally Posted By: bdcardinal
If anything having drain and fill plugs, some have dipsticks, with added capacity are worth the money.
The ones that are also girdles to preload the main carrier bearings are helpful when trying to make a diff stronger or handle more power than they were designed to handle.
I think buddy is implying that simply increasing the capacity could change what level the diff ran at, thus increasing parasitic losses. That's why he mentions how the different fill plug location among different manufacturers on the same diff could be explained by pinion angle.
Diff covers are total bling, be it a Mag-Hytec or a transparent one. I'd like to see a deep, finned aluminum trans and oil pan tested to see what effect they have on their respective fluids.
My Mustang came factory with a "bling" diff cover that increases capacity. There are drain and fill plugs on it, but the actual housing still has the fill plug which you take out to set level.
EDIT: To clarify it is just like putting on a larger oil pan. Capacity is increased but the level stays the same.
If it came from the factory it cost you nuttin and doesn't fit the context of what we are discussing.
The cost of the cover would pay for a lot of fluid for a rear end with a stock cover. That's probably a more prudent choice, but does not look as cool.
