Hi folks,
OK has anyone figured out how to "VACUUM" the oil out of a BMW Motorcycle Final Drive (Pic attached)
There has to be a way of extracting the old oil without having to dismantle virtually everything on the rear end and turn downwards to drain. Have figured out that using two Hydraulic jacks and a piece of pipe through large hole in Diff Hub the bike REAR can be raised high enough to refill with Gear oil.
There has to be an easy way of doing this simple task ?? BTW in case you don't know THERE IS NO BOTTOM DRAIN PLUG !
Cheers and thanks from Marty
