Originally Posted By: rooflessVW
Originally Posted By: bdcardinal
You just need a quick disconnect tool which NAPA most like sells and you can do it yourself. I know my place would charge at least $50 labor purely for having to lift the car, deactivate the fuel system, changing the filter, and the reactivating the system.
Tool for what? You squeeze them with your fingers and they leak a little then pop right off.
Ahh forgot they switched to that from using the quick disconnect tool setup. They eliminated the fuel filter the next year, mine only has the sock in the tank.
