What ratio do you use when adding oil to vehicle fuel?
Originally Posted By: dblshock
I've been running 1oz TC-w3 to 5 gallons in all my t4's for 10+ years.
Looks like you've got some oil deposits on the center of the piston there. Maybe some good PEA-based cleaning is in order?
I typically use a 50/50 mix of Lucas UCL and Supertech TCW3 ... about 3-4 ounces in a 14 gallon tank. I do this once every 2-3 tankfuls.
Cujet, ever tried using Schaeffer Neutra n131 to more thoroughly clean up those vales while you are lubricating them?
