I have a 2010 Hyundai Genesis Coupe with a little over 205,xxx miles at the moment and I drive a lot of highway miles. I have General GMAX AS-03 tires all around. The fronts have about 34,000 miles on them with a majority of the tread left and were installed 12 months ago The rear tires have about 40,000 miles on them with about 50% tread left and were installed 13-14 months ago. They are staggered from the factory and have never been run low on air. All of the suspension components that can wear out (shocks/struts/mounts/tie rods/etc) have been replaced within the past year and a half (50,000 ish miles) and the car has not been lowered. I have a lifetime alignment and balancing thing through Firestone and just got everything aligned and balanced at 197,xxx miles before a road trip (TX, NM, CO). Everything passed inspection then and had no issues.
I started to get some vibration in the wheel and assumed it was time for a rebalance again since low profile tires are a bit touchier when it comes to losing some of the balance over time. Go in this morning and they say they won't balance the wheels due to it being pointless and took me into the shop to show me the tires. There was cupping evident on all of them, and high spots from the belts starting to separate. On all 4 tires. How is it possible that all 4 tires suddenly have belts separating? I can see a manufacturing defect on one tire batch, but they are different sized tires thus would be a different batch. Whatever caused it happened within the past 7,000 miles (month and a half) in which I have done a road trip from TX to NM to CO and back, and just driving around on the highways in Texas. I haven't hit anything with every single tire and if it was caused by hitting something the only thing I can think of is the series of speed bumps in my apartment complex...but even still that shouldn't cause 4 tires to separate tread.
Thoughts? Input?
Thoughts? Input?
