I own the following wen pressure washer Wen 2800 power washer The manual gives me a chart for help determining what viscosity oil to choose and seems to recommend 30w oil for a starting temp of 40 degrees F or higher but a sticker on the machine next to the dip stick says to use 10W30 motor oil. So which is it? Does it even matter as long as it’s some kind of 30w oil? Here is a pic of the chart given in the manual. Right now it’s got Valvoline 30w oil that’s about to be changed (break in period first 8 hours use).
