Just finished an amazing repair on a 2013 Chevy Express 3500 which has PTO driven equipment like my trucks do.
It looked like some ham fisted idjit had failed to properly tighten the crank pulley on the 6.0 gas engine. Sounds bad but was actually much worse!
The pto drive looks like a supercharger pulley and bolts to an adapter that is through-bolted by the crank pulley. The idjits actually STRIPPED THE CRANK BOLT! OMG!
Well, my incredible BIL who is a third gen machinist and quite the wizard found a drill bit, tap, and heli coil for it. We actually did this in truck! Some tricky measurements placed the heli coil properly and bingo, we had a fully tightened (37 ft/lbs then 140 degrees) TTY crank bolt.
Then comes the critical part. That drive pulley secures with 4 bolts to the adapter and must be trued up with a dial indicator to less than .003 out. We actually got it to .002 but my BIL said that is within the movement of the crank snout due to bearing clearances. This makes it imperceptible when driving the rig.
The owner owes me a NICE dinner!
