Originally Posted By: bdcardinal
We have been doing lots of evaporators on 2015+ Mustangs. For a long time we had to do the whole heater box, Ford finally came out with an update where we can get just the core now.
It's big talk on the Mustang chat boards. Have you inspected any failed evaporators to determine what fails and causes it to leak - cracked weld, cracked tube, ??
Also read that Ford has updated the evaporator a couple of times, but they keep failing. Any inside info on the problem?
I just threw the whole housings away and now toss the evaporators in the beer money scrap pile when Ford says to scrap them. Ford doesn't even call them back anymore so you know that means it is a common problem.
Not sure of the update change, but they went from doing a whole heater box to just the evaporator core.
It would be interesting to take a failed evaporator and pressurize it with some air and put it under water to see where these leaks are occurring - similar to what a shop does to test a radiator for leaks. Nobody has ever said where the leaks happen in the AC evaporators, or has come up with a root cause (ie, bad welds, bad aluminum - too brittle, etc?).
Ford came up with a procedure to just replace the evaporator core because they are losing their [censored] on warranty claims on that part.
