On. For some reason my Mityvac would not pull fluid from the caliper. Simply would not pull a vacuum, it was like the bleeder hole in the caliper was tapped just a bit too large for the bleeder screw provided--it would just pull around the threads. But leaving the screw loose seemed to let gravity fill up, and a spin didn't reveal a spongy pedal. Doesn't go to the floor if I stand on it, I'd prefer it a bit higher but I think it's all and well now. Quick spin and both rear brakes were about the same temp, and I don't hear a pad dragging now if I rock the vehicle by hand.
