Solder is of course better for electrical connectivity but more of a pain. Especially with low temperature wire insulation that will shrink and melt on you. You have to make a good mechanical connection between the wires before soldering. side by side is not as good as J hooks. I don't like Jhooks because they tend to leave pointy ends stickout out. I like to push the stranded ends about 1/2" inside each other then twist slightly to hold them together. Then solder a football shaped joint. nice and smooth. then liquid tape followed by heat shrink for water proof seals.
That is a pain under a dash or in tight spaces. get a GOOD crimp tool and the proper sized scrimps for the wire being use and you will be much more efficient. Practice on a few wires, you should do a pull test and the wires will break before the pull out of the crimp. Ideally the wires break outside the crimp site.
Much faster.
That said in my youth in the 80s, I install may car stereos with only twisting about 3/4" of stripped ends together then wrapping with black tape.
I was known for very good and reliable installs for the 3 years in High school I did it. My own car lasted many years after high school with twisted and taped connections in south Texas with high humidity.
Don't sweat it too much.
Much faster.
