I recently deleted the DPF, Catalyst, EGRs and urea injection from my 2011 BMW 335d, and have the JR 2.8 tune. The car produces significantly more torque and horsepower, and I think it’s prudent to start using a new oil that is not compromised by emissions control longevity considerations. I understand the idea behind using an oil formulated with low sulfated ash with regard to protecting DPFs and catalyst systems, but I’m no longer constrained by those considerations and am more concerned with wear protection, sludge prevention, deposit control and the care and cooling of turbo bearings. From what I’ve read, the LL01 and LL04 specifications are the compromise of wear protection, reduction of sulfated ash combustion byproducts while still claiming extended drain intervals (on paper at least).
A lot of people in the forums are running Rotella T6 in similarly modified 335ds and X5 35ds - but the specs read more like it’s an old big truck synthetic engine oil, not a modern automotive Diesel engine oil. Not that T6 is a bad oil, because it’s not - however, I’m looking for better and more application appropriate options. While it’s great to see what others are running - I would greatly appreciate rationale and logic behind any recommendations. Thank you.
