Just purchased a 2015 Lexus GS350 which takes 235 x 45 x 18 tires. I have snow tires on wheels from my 2016 Lexus IS 300 which used 225 x 40 x 18 tires.
The alloy wheels are the same width, offset and bolt pattern. The diameter of the tire is 1.2" smaller. 26.3" v 25.1"
Can you think of any reason not to use these tires this winter? Ground clearance decreased 1/2" and speedometer error are the only downsides I can see.
Your thoughts?
Your thoughts?
