second Betta won’t eat bloodworms
by BossMoss. 04/19/19 01:03 AM
Battery Chainsaw - new purchase
by Shannow. 04/19/19 12:32 AM
PQIA six new 5w20 samples tested (name brands)
by SlavaB. 04/18/19 11:49 PM
MotoTech oil sale @ Fred Meyer
by SlavaB. 04/18/19 11:40 PM
being a luthier/
by koffy. 04/18/19 10:31 PM
2019 GMC Syclone
by oilpsi2high. 04/18/19 10:11 PM
KYB Struts from Rock Auto
by Snagglefoot. 04/18/19 10:10 PM
Thump/slap after rear pinion seal replacement
by HoosierJeeper. 04/18/19 09:55 PM
Dealer bulk oil
by leeaspell. 04/18/19 08:44 PM
Help me identify this tie rod washer
by Klutch9. 04/18/19 08:40 PM
Sears suing Lampert for looting them
by slacktide_bitog. 04/18/19 07:45 PM
Champion COS10575 bypass pressure
by Snagglefoot. 04/18/19 07:39 PM
New oil filter cutter
by kstanf150. 04/18/19 07:26 PM
Cat 435-5142 // 2016 LML duramax
by Shata. 04/18/19 06:52 PM
Free to all: Assassin's Creed Unity (PC)
by Rand. 04/18/19 06:29 PM
AC DELCO "PROFESSIONAL" PF 64 CUT OPEN
by 53' Stude. 04/18/19 05:47 PM
Offset
by jcartwright99. 04/18/19 04:07 PM
Honda Camera Design...FAIL
by Sayjac. 04/18/19 04:02 PM
rotella t4 vs delo
by 1978elcamino. 04/18/19 03:50 PM
fatafox, CurtC, LockCracker, fawkes, Kenzitoz
67848 Registered Users
51 registered members (Astro14, billt460, A1O, 87sammy, 2015_PSD, bmod305, 4 invisible), 658 guests, and 25 spiders.
Topics287,727
Posts4,933,169
Members67,848
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Observation with Rislone [Re: MVFarms] #4840427
08/14/18 08:55 PM
08/14/18 08:55 PM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
yep, it was that one . . .
Re: Observation with Rislone [Re: MVFarms] #4843553
08/18/18 08:47 AM
08/18/18 08:47 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
How many quarts does your crankcase hold?
The Rislone may need longer to work. Or it may need another 16.9oz application, a thousand miles prior to an oil change. I've used it with success in the past. Any engine that holds more than four quarts may need more than just 16.9oz. I know Walmart sells the Rislone in quart bottles and I've had better results using the quart bottle over the Concentrate.
It's probably too late to add the quart bottle. That will thin the oil too much. So try another 16.9 if need-be..... should your crankcase hold 5-6 quarts capacity, using a thicker oil like 15W40.
Just my opinion -- my experience working at home with Rislone and gas-driven engines in the past 45 years.
2019 Hyundai SantaFe 2.4 GDI Castrol Edge 5w30 / NAPA Mann-Hummel Pro Select filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Observation with Rislone [Re: MVFarms] #4846784
08/21/18 05:42 PM
08/21/18 05:42 PM
South East Asia
kr_bitog Offline
kr_bitog  Offline
South East Asia
Originally Posted By: MVFarms
My daily driver junker truck is a 1992 F150 with the 4.9 . . . Operating temp is always just under 210F (read on a mechanical gauge).
To try and quiet a lifter tick, I added a bottle of the Rislone concentrate to the Traveller 15w-40 that's in it, probably at about the middle of an OCI.
Truck was/is immediately running about 5 degrees cooler. Nothing else was changed.
I don't think it was any reduction in viscosity, as it ran the same temp on SN 10w-30.
Any thoughts?
It is possible, 5 degrees F is quite minimal and it is possible to be impacted by additive added. I have similar observation with Lubegard added to the oil as well. It keeps engine oil temperature colder by 1-2 degree Celcius and the engine takes longer before reaching operating temperature.
Page 2 of 2 1 2
