We are in the process of renovating a room in our basement. The room is about 20' long, 9' deep. with a load-bearing beam splitting the room in half the short way (so two 10'x9' rooms essentially, beam hangs down about 8"). We are lighting the room with can lights, same as the rest of the basement. This room has a low ceiling height, at about 7'6" to the bottom of the beams. So far, I have installed 2 LED can light retrofits on each side of the beam; they are 'centered' in each side, about 6' from each other. The light output is good, about 830 lumens per unit, but obviously there are still darker spots on the walls and in the corners; these lights have a fantastic beam spread (120 degrees IIRC), but that's still the nature of can lighting. I was considering changing the layout to 4 lights per side, arranged in a square, but that seems like an absurd amount of light in that size room. Besides, they are intense if you happen to look directly at them. They will be dimmable, FWIW.
We had considered adding one 60w equiv omni-directional bulb to each side, on a separate switch, in case we needed more light, but I don't know if that'd look very good. We tested it with a temporary wire in place, and it definitely helped though. Any ideas to address light distribution with a short ceiling height?
