'20 Hyundai Sonata -- Wow-ee! Looks!
by paoester - 12/10/19 07:11 PM
2021 Chevrolet Suburban and Tahoe Revealed
by E365 - 12/10/19 06:56 PM
Do you try to book on widebodies?
by fdcg27 - 12/10/19 06:25 PM
Carbon Farming
by SubLGT - 12/10/19 05:40 PM
How Many Vehicles Do You Maintain?
by Passport1 - 12/10/19 04:23 PM
Bypass Setting vs Subaru
by Al - 12/10/19 03:10 PM
13 chevy equinox I4 engine oil in filter box
by Fitter30 - 12/10/19 02:04 PM
Driven - Direct Injection Oils
by buster - 12/10/19 01:59 PM
.308 Win or .25-06
by mobilaltima - 12/10/19 01:05 PM
FI cleaners ruin injectors?
by Redright9 - 12/10/19 12:54 PM
Planned Changes at Honda
by The Critic - 12/10/19 12:30 PM
The forgotten Bolens 1253
by Lubener - 12/10/19 11:49 AM
Valvoline High Mileage vs Valvoline Full Synthetic?
by Bettez88 - 12/10/19 10:33 AM
Anything to quiet a noisy Subaru front differential?
by anarchyx34 - 12/10/19 10:15 AM
Consumer Cellular
by CourierDriver - 12/10/19 09:53 AM
Ford 6.2L
by ford46guy - 12/10/19 09:30 AM
2012 Hyundai Santa Fe lights on dash issue
by Urshurak776 - 12/10/19 08:25 AM
Electronic Parking Brakes- Long Term Reliability?
by LoneRanger - 12/10/19 08:17 AM
New Kitchen Faucet Selection: To Pex or Not to Pex ?
by LoneRanger - 12/10/19 07:41 AM
possumdog, TwoTrax, Cmac83, Faresca, BucDan
70092 Registered Users
123 registered members (2_Tall_Mitchell, 77GrandPrix, Al, 14Accent, 4WD, 87sammy, 12 invisible), 1,994 guests, and 29 spiders.
Topics298,550
Posts5,137,862
Members70,092
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838999 08/13/18 11:15 AM
CT8 Offline
Very basic ,,, generates a voltage because of the difference between the air on the outside of the sensor and the gases inside the exhaust pipe. volts tell the computer what it needs to do. The AF ratio is an average.
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4839024 08/13/18 11:56 AM
J
Johnny2Bad Offline
J
By measuring the oxygen content of the exhaust they can infer the air / fuel ratio being burned in the engine.
This will cause adjustments in the engine operating parameters by the Engine Control Module [Computer] (ECM). It also plays a role in catalytic converter operation ... cats work at a certain elevated temperature, the computer can add oxygen to the A/F mix to increase the Exhaust Gas Temperature which heats up the Cat, then reduce the oxygen content once the cat is working properly to reduce emissions and increase fuel economy and power when needed.
Bad O2 sensor will clearly affect fuel economy and emissions, neither for the better.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4839035 08/13/18 12:12 PM
9
97prizm Offline
9
Yes as said above 02 sensors typically are 1 in front in behind the cat to look at the unburned oxygen levels, but not always. There are heated O2s and plain O2 sensors. Don't replace the wrong sensor or you could fail an emissions test. The VECI sticker under the hood will tell you what emission components your vehicle will have.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Purpose of the....02' Sensor [Re: 97prizm] #4839071 08/13/18 12:51 PM
Malo83 Offline
Helps me pass smog checks here in Cali! LOL
Re: Purpose of the....02' Sensor [Re: Virtus_Probi] #4840307 08/14/18 06:12 PM
O
Oregoonian Offline OP
O
Thanks for that web page...Provided good info.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Page 2 of 2 1 2
