M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
best way to buy a new vehicle?
by WhyMe. 01/15/19 11:07 PM
Cat Humor
by StevieC. 01/15/19 11:06 PM
Lightning McQueen (Humor)
by StevieC. 01/15/19 11:04 PM
Fastest Land Mammal (Humor)
by StevieC. 01/15/19 11:01 PM
Wifes says decorate the baby's room (Humor)
by StevieC. 01/15/19 11:00 PM
Taco Bell (Humor)
by StevieC. 01/15/19 10:57 PM
Van full of money (Humor)
by StevieC. 01/15/19 10:56 PM
Amazon Packaging (Humor)
by StevieC. 01/15/19 10:55 PM
Star Spangled Banner in school (Humor)
by StevieC. 01/15/19 10:52 PM
Maybe on to something? (Batman Humor)
by StevieC. 01/15/19 10:49 PM
Canadian Breakfast (Humor)
by StevieC. 01/15/19 10:48 PM
Tinder Anyone? (Humor)
by StevieC. 01/15/19 10:45 PM
(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
28 registered members (chance, AurionX2, Black_Thunder, Aero540T, 240_Ed, 4 invisible), 932 guests, and 35 spiders.
Topics296,629
Posts4,955,954
Members66,950
Most Online2,577
Jan 14th, 2019
Observation with Rislone #4839063
08/13/18 12:37 PM
08/13/18 12:37 PM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
My daily driver junker truck is a 1992 F150 with the 4.9 . . . Operating temp is always just under 210F (read on a mechanical gauge).
To try and quiet a lifter tick, I added a bottle of the Rislone concentrate to the Traveller 15w-40 that's in it, probably at about the middle of an OCI.
Truck was/is immediately running about 5 degrees cooler. Nothing else was changed.
I don't think it was any reduction in viscosity, as it ran the same temp on SN 10w-30.
Any thoughts?
Re: Observation with Rislone [Re: MVFarms] #4839081
08/13/18 01:00 PM
08/13/18 01:00 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
My first thought is that I'm surprised the thermostat isn't regulating it to the set temperature.
1994 BMW 530i, 240K
1996 Honda Accord, 268K
1999 Toyota Sienna, 408K
2000 Toyota ECHO, 280K
Re: Observation with Rislone [Re: kschachn] #4839084
08/13/18 01:04 PM
08/13/18 01:04 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
True
It should still run the same temp.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive236K miles
PPHM 5w30 x 2 Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Observation with Rislone [Re: kschachn] #4839092
08/13/18 01:12 PM
08/13/18 01:12 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Only to some extent under ideal conditions. Example.. In stop and go bumper to bumper traffic on a hot summers day the fan(s) may not be bringing enough air across the radiator to extract the heat from the coolant as air coming through it at driving speeds. It can and many do eventually overheat.
The thermostat cant open more than fully.
A reduction in friction will reduce the amount of heat generated inside the engine and absorbed by the cooling jacket. Make sense?
Re: Observation with Rislone [Re: MVFarms] #4839102
08/13/18 01:27 PM
08/13/18 01:27 PM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
I 'blame' the 210ish temps to an old/partially clogged radiator . . . but it's consistently run there for years.
I can watch the thermostat open and close (it's a 195F) but I'm not measuring temp at the thermostat housing . . . the bulb is basically in the water jacket between cylinders. Temps vary depending on where you're taking the measurement.
. . . example, assuming the thermostat is close to accurate at 195F . . . when coming up to temp, my gauge goes to 215 before the 195 thermostat opens and drops it back down. Water temp is a 'localized' measurement, not average. Thermostat housing is getting less heat generated and much more airflow than the side of the block.
Once you're consistently over 195 (which you should be for fuel efficiency) it's the radiator's job to regulate the temp.
I haven't worried too much about the temp. Just curious about the drop.
Re: Observation with Rislone [Re: Trav] #4839114
08/13/18 01:37 PM
08/13/18 01:37 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
The first one, yes. The second one no. In order for the second scenario to work and actually lower the temperature of the coolant would require him to magically be operating right at the heat load that just barely keeps the thermostat open. Otherwise the thermostat would just throttle down slightly and keep the same temperature. Overall heat rejection lower, OK I'll envision that. But not a lower temperature. That's controlled.
1994 BMW 530i, 240K
Re: Observation with Rislone [Re: kschachn] #4839143
08/13/18 02:03 PM
08/13/18 02:03 PM
Trav Offline
Trav  Offline
Right. As long as the engine was still controllable by the thermostat your right. If the thermostat was wide open and air movement was not drawing as much heat as being generated then a reduction in friction will reduce the temperature.
By how much I have no idea as most of the heat is from combustion being transferred to the cooling jacket.
Re: Observation with Rislone [Re: MVFarms] #4839311
08/13/18 05:18 PM
08/13/18 05:18 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I think the Rislone might have thinned the oil which in turn cooled the engine better than the 15W40 was.
God Bless Our Troops
Re: Observation with Rislone [Re: MVFarms] #4839328
08/13/18 05:41 PM
08/13/18 05:41 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Crazy thought. 210 F is close to boiling. Is the cap any good? You may wanna try a thinner oil next change.
Thick oil is better grin2
Re: Observation with Rislone [Re: MVFarms] #4839380
08/13/18 06:42 PM
08/13/18 06:42 PM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
Cap is fine and thermostat is fine, both are about 1.5 years old . . . truck has run this oil and this temp for about 100,000 miles and ran the same temp with the predecessor rad cap and thermostat (that I changed out when I replaced the original water pump (at the 25 year mark).
Yes, 210F is close to boiling . . . with no glycol and no pressure.
The good cap and pressure are exactly what allows it to run just fine at 210.
210F is absolutely normal operating temp for the majority of 'modern' engines out there, dummy gauges have just made us forget that.
I don't think that it was the thinning of the oil that reduced the temps . . . truck ran the same temp with 10w-30.
Re: Observation with Rislone [Re: MVFarms] #4839387
08/13/18 06:49 PM
08/13/18 06:49 PM
St. Louis, MO
Lawn_Care Offline
Lawn_Care  Offline
St. Louis, MO
Throw in some MMO and really watch this thread take off.
hide
True victory does not come from defeating an enemy. True victory comes from giving love and changing an enemies heart.
Re: Observation with Rislone [Re: Lawn_Care] #4839532
08/13/18 09:37 PM
08/13/18 09:37 PM
Trav Offline
Trav  Offline
hide
crackmeup
Re: Observation with Rislone [Re: MVFarms] #4839830
08/14/18 10:06 AM
08/14/18 10:06 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
The Rislone product is about a 20 grade oil so a reduction in oil viscosity is possible.
Using a 15W40 in an engine engine speced for a 30 grade oil will raise engine temperatures slightly, so if the 40 grade temp was lowered by the thinning the oil with a 20 grade, the temp difference might be a few degrees.
Rislone can clean certain engine components such as VVT valves and hydraulic lifters.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Observation with Rislone [Re: MolaKule] #4839982
08/14/18 12:32 PM
08/14/18 12:32 PM
Trav Offline
Trav  Offline
He used the concentrate 16oz bottle IIRC, is it still 20w?
Re: Observation with Rislone [Re: Trav] #4840406
08/14/18 07:34 PM
08/14/18 07:34 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
If it is this product it is still a 20 grade:
https://rislone.com/wp-content/uploads/2014/11/4102-Tech-Sheet1.pdf
