Pies: which ones do you love?
by 53' Stude - 12/15/19 02:32 PM
Honda Ridgeline ZF 9 Speed
by dakota99 - 12/15/19 12:02 PM
Selling my dump trailer
by Sunnyinhollister - 12/15/19 11:43 AM
Motorcraft 5W-20 canada
by xXF150Xx - 12/15/19 11:40 AM
Brake caliper pins
by Donald - 12/15/19 11:14 AM
Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
Royal Purple Max-Tane
by RogerBacon - 12/15/19 07:32 AM
Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
xXF150Xx, NCBuckeye, Maik, Pluckster, DerekPho
70131 Registered Users
88 registered members (53' Stude, ABerns, 928, 10 invisible), 2,015 guests, and 25 spiders.
Topics298,832
Posts5,142,289
Members70,131
Most Online3,589
Nov 2nd, 2019
Page 2 of 2 1 2
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838999 08/13/18 11:15 AM
CT8 Offline
Very basic ,,, generates a voltage because of the difference between the air on the outside of the sensor and the gases inside the exhaust pipe. volts tell the computer what it needs to do. The AF ratio is an average.
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4839024 08/13/18 11:56 AM
J
Johnny2Bad Offline
J
By measuring the oxygen content of the exhaust they can infer the air / fuel ratio being burned in the engine.
This will cause adjustments in the engine operating parameters by the Engine Control Module [Computer] (ECM). It also plays a role in catalytic converter operation ... cats work at a certain elevated temperature, the computer can add oxygen to the A/F mix to increase the Exhaust Gas Temperature which heats up the Cat, then reduce the oxygen content once the cat is working properly to reduce emissions and increase fuel economy and power when needed.
Bad O2 sensor will clearly affect fuel economy and emissions, neither for the better.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4839035 08/13/18 12:12 PM
9
97prizm Offline
9
Yes as said above 02 sensors typically are 1 in front in behind the cat to look at the unburned oxygen levels, but not always. There are heated O2s and plain O2 sensors. Don't replace the wrong sensor or you could fail an emissions test. The VECI sticker under the hood will tell you what emission components your vehicle will have.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Purpose of the....02' Sensor [Re: 97prizm] #4839071 08/13/18 12:51 PM
Malo83 Offline
Helps me pass smog checks here in Cali! LOL
Re: Purpose of the....02' Sensor [Re: Virtus_Probi] #4840307 08/14/18 06:12 PM
O
Oregoonian Offline OP
O
Thanks for that web page...Provided good info.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Page 2 of 2 1 2
