This oil looks interesting but not avail in US
by jkhawaii - 12/11/19 10:39 PM
Castrol Engine Shampoo (Oil Flush)
by adams355 - 12/11/19 10:03 PM
How Dumb can she get #2
by KeithS_NW_Ohio - 12/11/19 09:45 PM
Dodge Transmission
by Butterbean - 12/11/19 09:38 PM
Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
oilylp, Motorapido, TyMillerfc, AcadiaDave, lmt1911
70106 Registered Users
55 registered members (bbhero, BLND1, bdcardinal, AZjeff, aquariuscsm, BlakeB, 2 invisible), 1,106 guests, and 26 spiders.
Topics298,605
Posts5,139,019
Members70,106
Most Online3,589
Nov 2nd, 2019
Purpose of the....02' Sensor #4838563 08/12/18 09:04 PM
O
Oregoonian Offline OP
O
What does it accomplish ???
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838600 08/12/18 09:50 PM
Stag Offline
The O2 sensors in a gasoline engine car works with the Engine Control Module to determine the oxygen content of the exhaust. This information is used during closed-loop operation to adjust the fuel injected to make the best charge for the conditions of operation. Except in modern OBD-2 (after 1996, I believe) there is a second O2 sensor behind each cat to monitor "catalyst efficiency".
'02 Isuzu Trooper 146k Syn/Mann
'01 Audi A4 Q 110K GC/Mann
'86 Volvo 240 5dr 430+K Dino/Mann
'98 Audi A-8 Q 150K GC/Mann
'07 Volvo S60 2.5T
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838602 08/12/18 09:52 PM
J
JamesBond Offline
J
It senses "02'" of course.
The simple answer is, it tells your fuel injection computer how much fuel to inject.
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838611 08/12/18 10:07 PM
R
Reddy45 Offline
R
Specifically, it is "O2" (2 Oxygen atoms) not "02" (zero two).
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838612 08/12/18 10:08 PM
T
Trav Offline
T
It maintains the stoichiometric ratio.
https://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio
There are a few different types of o2 sensors AKA Lambda sensor.
https://o2sensors.com.au/static/what-is-oxygen-sensor
Re: Purpose of the....02' Sensor [Re: Reddy45] #4838736 08/13/18 04:44 AM
W
weasley Offline
W
Being really specific it is O2. grin
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838766 08/13/18 05:38 AM
SOHCman Offline
It senses if you watch the Oxygen network.
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Purpose of the....02' Sensor [Re: weasley] #4838770 08/13/18 05:58 AM
spasm3 Offline
I can't seem to type that! Did you copy and paste? I end up with O2.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Purpose of the....02' Sensor [Re: Trav] #4838774 08/13/18 06:08 AM
V
Virtus_Probi Offline
V
Very helpful webpage!
I worked on an interface circuit for what sounded very much like a wideband oxygen sensor for a US OEM quite some time ago.
Very delicate little design, had me pulling my hair out for a couple of months...
2014 Forester XT, 105000 miles
Last Change;
PP 5w30 d1G2
Tokyo Roki 15208AA170 filter
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838787 08/13/18 06:32 AM
dbias Offline
A lot. They help maintain a 14.7 to 1 air to fuel ratio. If O2 is high engine is considered to be running lean so ECU tells injection to add more fuel and the opposite if running rich. Adjustments to the short and long term fuel trims show the ECU trying to maintain the ratio.
Gummed up MAF or unmetered air throw things out of whack
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: Purpose of the....02' Sensor [Re: spasm3] #4838798 08/13/18 06:46 AM
supton Offline
Hit quick quote on his post and you can see the code.
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838808 08/13/18 06:58 AM
O
Olas Offline
O
Commonly, O2 sensor is part of a feedback loop for closed loop operation.
Less common is a wide band O2 driving an AFR gauge on the dash and/or helping a new ecu to self-learn.
Cable ties should hold it
Re: Purpose of the....02' Sensor [Re: Oregoonian] #4838843 08/13/18 08:04 AM
P
partspro Offline
P
Not exactly 14.7 to 1. The ECU fluctuates the mixture between rich and lean which results in a cleaner exhaust. If you watch the O2 sensor you will see it 'toggle' or switch, many times a second.
Re: Purpose of the....02' Sensor [Re: partspro] #4838885 08/13/18 09:17 AM
supton Offline
Does that for one or two reasons (not completely sure if both are "required"): first, the upstream O2 sensor (the one before the cat) will see that wide swing. But the downstream (after cat) should stay at 14.7:1 if the cat is working properly. Once it starts to swing also, that tells the ECU that the cat efficiency is not as good as it should be. Second reason it may cycle like this is to run rich momentarily and make the cat do more work--by doing so will boost the cat temperature. I doubt this is needed at cruise speed on the highway but at idle it may be necessary to keep the cat hot.
Re: Purpose of the....02' Sensor [Re: SOHCman] #4838912 08/13/18 09:50 AM
9
9050lx Offline
9
"It senses if you watch the Oxygen network."
An Oprah sensor?
