Old rationing video
by 53' Stude - 01/21/20 03:32 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1â„¢ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
106 registered members (1978elcamino, 1WildPig, 2000ltdken, 2015_PSD, 65convertible, 28oz, 4 invisible), 2,316 guests, and 20 spiders.
Topics300,400
Posts5,174,972
Members70,497
Page 2 of 2 1 2
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: danez_yoda] #4838277 08/12/18 03:30 PM
CR94 Offline
Originally Posted By: danez_yoda
... your 4banger should be fine with a lightweight aerodynamic car.
Huh?! That's not exactly a description of an xB.
2011 Toyota Prius now at 107K
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4838283 08/12/18 03:35 PM
CT8 Offline
Originally Posted By: BoostedSwede
Hey everyone,
I'm sure this has been answered before, but I'm looking for a definite answer for my application. I own a 2014 Scion xB with the 2AZ-FE 2.4L engine. I currently have 55k miles on it. Toyota recommends either 0w-20 or 5w-20 oil with a 5k mile OCI. They do not specify if this OCI is on synthetic or dino oil. I've been running Mobil 1 5w-20 synthetic and changing every 5k with no issues.
However, I just took a job with an 80 mile daily commute. This car now sees 80 miles of highway driving each day, where it sits between 3,500 and 4,000 rpm. Should I move up to a 5w-30? Can I extend to a longer OCI so I can do fewer changes per year? At this rate I will put 35k annually on this vehicle.
I'm looking to keep this car for the long haul...150k-200k miles. I need to make sure I'm taking care of it now. Thanks for any help!
You can run ANY properly rated oil and have your car last as long as it possibly can last. Running M1 5W-30 could give you 10,000 mile 1 year intervals and be called conservative. Make sure the air filter base and intake plumbing is well sealed.
2015 F150 2.7
2018 F350 6.2
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: CR94] #4838286 08/12/18 03:37 PM
B
BoostedSwede Offline OP
B
HAHAHAA
So true.
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4838289 08/12/18 03:39 PM
H
HKPolice Offline
H
Run 0w30 in winter. 5w30 won't do your engine any good @ redline when it's cold.
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4838290 08/12/18 03:40 PM
B
B
Alright, so from these answers, I think I will move to a 5w30, stay with a well known synthetic, and get a UOA done at 5k miles on my next change...see if I can move to 10k OCI.
On a side note...I want to change the manual transmission fluid. The OE fluid is very notchy/stiff when cold. Any recommendations there? I've gathered that I should stick with a GL4 lube, even thought the manual says I can use GL4 or GL5.
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4838348 08/12/18 04:58 PM
53' Stude Offline
I'll vote M1 5w30 EP as I believe bullwinkle has had success in his XB with it smile
Good enough for me
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4838453 08/12/18 06:50 PM
J
JAG Offline
J
In this case, a UOA at 5k miles is too short, in my opinion. 8k miles is what I would do the first UOA at with Mobil 1. I would actually choose Amsoil Signature Series and go 11k miles. With long OCIs, it becomes extra important that the air filtration system is well-sealed.
For manual transmission fluid, I would use Amsoil’s most appropriate product (I don’t know which one that is). Red Line would be my second choice.
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4838481 08/12/18 07:25 PM
A
Armkb Offline
A
Originally Posted By: dogememe
4k rpm? How fast are you commuting at??
I typically cruise between 80-90 mph. 90 is 4k rpm with my 5 speed tranny.
Typical Connecticut driver! Idiots out there. Stay off Rt.84 & 684 where I drive please!
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: Armkb] #4838913 08/13/18 09:51 AM
B
B
I actually learned to drive in MA, and am fairly new to CT. Not sure if that makes it better or worse!
And to be fair, traffic on I-91 (my normal drive) usually is moving at 85 in the left lane.
Thanks for your opinion!
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4839070 08/13/18 12:50 PM
blupupher Offline
By '14 the oil ring issue had been taken care of (supposed to be done by MY 2012).
Me, I am just going to run xw-20 and change it every 5000 miles.
If I was doing an 80 mile commute, I would probably do it every 10,000 miles (if using synthetic).
Actually I would find a closer job, but that is another topic. I am done with long commutes.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: BoostedSwede] #4851176 08/26/18 12:02 AM
hank2 Offline
I think I posted this before, but here's the actual Warranty policy bulletin.
The Scion xB is on the problem list through the 2015 models, which was the end of production for that model. All the other Toyota and Scion models went to revised engines before the xB.
Toyota POL14-12
The other Toyota/Scion models year ranges that used that problem 2AZ engine (in some cases it was an optional engine, eg. Corolla, Matrix)) are shown on the dealer communication. Of course, not everyone has had bad oil consumption, depending on vehicle use, driving habits, maintenance or just luck.
2014 Scion xB; Cast Edge or MT 5w20, Mahle
2013 Scion xD; Valv. Advd 0w20, Mahle or Wix
1982 Dodge D150, slant 6, 833OD. ST 10w30 himil. +ZDDP,
1981 Suzuki GS650G, Valv. 4T 10w40, Hiflofiltro
Re: Beating a dead horse - 2AZ-FE oil visocsity [Re: hank2] #4851488 08/26/18 12:55 PM
CR94 Offline
Originally Posted By: hank2
... Of course, not everyone has had bad oil consumption, depending on vehicle use, driving habits, maintenance or just luck.
I've yet to see a good explanation which combination of those factors makes the difference, and why, although speculation is not hard to come by.
Likewise with the 2ZR-FXE, which sometimes guzzles oil too.
Page 2 of 2 1 2
