Hello,
My old Accord with the F22B2 engine started seeping oil through all the gaskets on the top end including the distributor seal, the spark plug tube seals and the valve cover. When I open the oil cap with the engine running there is quite a bit of air coming out of the hole, more than there used to be a couple of years ago. I ran both a compression and a leakdown test and these are the results:
Cylinder 1, 2, 3, 4
Compression: 190, 189, 190, 210
Leakdown Percentage: 8%, 13%, 11%, 4%
The compression test would probably be considered a wet test since there was more than a little bit of oil that leaked down into the cylinder when I removed the spark plug. The leakage heard during the test was from the valve cover, I didn't hear anything out the intake nor the exhaust. The compression test was done cold and the leakdown test hot.
I don't know exactly what these results indicate, anyone care to comment? I found this online:
http://www.gregsengine.com/cylinder-leakdown-testing.html
Cylinder 1, 2, 3, 4
