Originally Posted by neo3
Is this compatible with the MC orange? Also, is it likely to have any benefit for water pump seal life?
As it's so new with little known about it, I'd make no assumptions. For now I'd use the topic AF if spec'd and would not mix with MC Orange, or use interchangeably.
And, considering the admonishment not to mix colors or types on the Yellow Coolant Spec sheet linked above, for now I'd follow that instruction.
