What break in procedure would you recommend for my rebuilt LS2 engine? It’s getting a full rebuild with piston rings, gaskets, bearings, etc. Reason it’s getting a rebuild currently is due to the 9 PSI I get at idle and a max of 18 PSI when cruising. Truck is cammed with a melling high pressure pump and a few other upgrades as well.
