UPDATE:
With the first storm we got in early November it was apparent that the engine was still not putting out rated power--it would stall out in just a few inches of fluffy snow. So, off to the repair shop it went. They said the valves were out of adjustment and fixed same. When I picked it up, it seemed to run better but sounded, how shall we say?. . . more "mechanical".
Last month we got a "blowable" amount of snow (a few inches) and the machine worked well--it seemed to make normal power and I was able to blow my yard and sidewalk as well as that of my neighbor. The problems started as I was doing another neighbor's driveway. I was clearing the discharge chute of some slush / ice and the engine was running--while pulling slush out of the chute I noticed the engine took on a different sound (more mechanical sounding) and then a few seconds later it stopped like it was turned off. That was the last time it ran.
Upon trying to restart it, I couldn't even turn the engine over with the pull start or electric starter. There was still oil in the sump, but it was just above the low mark on the stick (I'd started with the oil at the full mark). NOTE: I'd changed the oil when I got it back from the repair shop because I thought it looked "glittery", which I chocked up to them lapping the valves and just poking around in the engine--that should have been my first clue. Now the oil really looks glittery. . .
I took it back to the repair shop and upon examination they said the cylinder was heavily scored and said that it would likely need other major repair to get it working again. They refunded my money for the earlier work they'd done.
At this point I declared Tecumseh as "dead to me". I know I could have re-powered it, but after some research it seemed like that effort may have required more time / effort than I was willing to do with the limited time I had before real winter set in and the limited space I have in my garage for such an endeavor.
I ended up buying a new Troy-Bilt 2410 with a PowerMore 208cc engine and just used it for the first time today--what a nice-running machine! It starts on the first pull and did a great job on the wet snow I moved with it today. I did three driveways and sidewalks on less than one tank of fuel. The engine never really bogs down--the engine just changes tone briefly, the governor kicks in and it just keeps spitting the snow out.
I realize it's new and it should run strong at this point, but it exceeded my expectations for power for a budget-priced snowblower. No regrets.
Does anyone have any idea why the Tecumseh died such an early death? I changed the oil in that EVERY year in the spring--whatever caused the failure was definitely NOT oil-related--it died with fresh, if not glittery, oil in the sump.
