CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
101 registered members (AdditiveOCD, ArrestMeRedZ, ARB1977, 2012AccentSE, 1978elcamino, 12 invisible), 2,151 guests, and 55 spiders.
Topics286,393
Posts4,907,448
Members67,614
Most Online2,967
Mar 10th, 2019
Top soil, triple mix or something else for top dressing lawn #4836888
08/10/18 10:08 PM
08/10/18 10:08 PM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
My lawn is in dire need of some soil. When we moved in years ago I said there is hardly any soil on our front lawn but I have always managed to make do.
This summer with the extreme heat/drought and not being around much to water/maintain it, it finally caught up with me.
I would like to add an inch or 2, maybe more in the lower spots but I am confused what type of soil I should use?
I don't plan on resodding, just using a good quality seed but at the same time I am worried, if we get a heavy rain, that a lot of it will be washed away as my front lawn is sloped somewhat.
My guess is, just some good quality soil that I can roll lightly after it is seeded and then water the heck out of it and hope it sprouts sooner rather than later.
Currently my lawn, like I mentioned, is in rough shape so should I till/loosen that up first or just throw/spread the soil over top of what's there?
Also, if anyone can recommend a good hearty, heat/drought resistant seed, I'd appreciate that too.
Although I never measured the front lawn, I am guessing it is roughly 30-35' by 20-25'?
For the smart a**es, keep in mind, many states are north of me and my lawn isn't covered 24/7 in snow like some of might think. spank
Alaska* Maine* New Hampshire* South Dakota*
California Massachusetts New York Utah
Connecticut Michigan* North Dakota* Vermont*
Idaho* Minnesota* Ohio Washington*
Illinois Montana* Oregon* Wisconsin*
Indiana Nebraska Pennsylvania Wyoming
Iowa Nevada Rhode Island
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4836897
08/10/18 10:26 PM
08/10/18 10:26 PM
PimTac Offline
PimTac  Offline
Pennzoil Platinum.
Cannot see signatures any longer so it doesn’t matter.
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4836899
08/10/18 10:28 PM
08/10/18 10:28 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
That lawn looks amazing. You should see mine. cry
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Top soil, triple mix or something else for top dressing lawn [Re: dishdude] #4836904
08/10/18 10:36 PM
08/10/18 10:36 PM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
Thats an older pic, it looks nothing like that now, trust me. puke
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4836906
08/10/18 10:38 PM
08/10/18 10:38 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
What's wrong with that? Far worse down here in lousy soil & extreme heat.
First, you should aerate. Not with one of those machines either. They don't work well on lousy soil. You'll have to do it by hand using metric-equiv. of 1/2 or 5/8" PVC with a right angle fitting hooked up to a garden hose. This will make larger holes + water deeper than any surface-only irrigation. Space each hole about 2'. On a downslope, angle the PVC so that as water runs off, it's caught in the water-made hole.
Second, spread a suitable fertilizer for both your grass & latitude.
Third, top dress with 50% sand & 50% compost or something similar. You'll need a good amount. Rake it out even.
Fourth, water all of this in evenly. At least an inch of water. Maybe more.
Fifth, wait two weeks.
I do this here albeit much further South, in lousy soil. Never had to reseed nor resod in 30+ years. Point is to make an environment for your grass to thrive! It will fill in and grow letting you know you're on the right track.
Works for me......
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4836908
08/10/18 10:54 PM
08/10/18 10:54 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Irv,
Do you know how much soil you have before you hit clay? I've used triple mix, soil as well as sheep manure (from Canadian tire) over the years. I've aerated my lawn twice in 15 years and put seed down every 2-3 years. I usually only add 1 - 1 1/2 inches of soil at a time. I take it into the lawn and then water it for the first 2 weeks.
Some guys dethatch the lawn as well before adding more soil. I'm thinking if you add too much soil at once, it's going to be a mess.
The other key I find is to cut my grass with the highest setting on my lawn mower. The grass stays much greener. Cutting it too short up here when we get a few weeks without rain turns that lawn brown fast.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4837027
08/11/18 07:17 AM
08/11/18 07:17 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
if you mulch cut high, fertilize and if necessary lime, and have a good night crawler population, your grass will makes its own soil. You can get a plug aerator, and then rake sand the plug holes, and water. The removed plugs need composted to break them down into soil. Then you can broadcast that. I do not know what cool season grasses do well there. Here Bermuda is the choice. And Crabgrass does extra well, although many do not like the light green color.
Rod
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4837053
08/11/18 07:52 AM
08/11/18 07:52 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Id go with compost if not too expensive. I just dump the bags and rake it to being a half inch. I wouldnt go with an inch or two, otherwise you might get the issue of run off. I must say Ive been successful with top soil as well. Are you going to order a truckload I assume? Hopefully the quality is good. As for seed, I like C-I-L but have had luck with others as well. Compost breaks down into the earth and is good for it. If your lawn is in rough shape id just repeat the process of a 1/2 inch and seeding every spring and fall for a couple years to build it up.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Top soil, triple mix or something else for top dressing lawn [Re: JC1] #4837057
08/11/18 07:56 AM
08/11/18 07:56 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Originally Posted By: JC1
Irv,
Excellent point on mower height, I do the same and my lawn did better than most in my city when we got extreme heat and drought this year. The longer blades of grass provide shade to each other from the sun. An aeration can also be a good place to start in fall, followed by compost and overseeding.
PP 0w20 & ST 4967
Re: Top soil, triple mix or something else for top dressing lawn [Re: JC1] #4837106
08/11/18 09:12 AM
08/11/18 09:12 AM
Oshawa, Ont. Canada
irv Offline OP
irv  Offline OP
Oshawa, Ont. Canada
Irv,
JC1, unfortunately I do not. I guess I should do some digging to find out but if I had to guess, I have very little to no topsoil.
My front lawn, imo, consists of dirt and not much of anything else. Talking with my neighbors, the contractor cheaped out with topsoil when these houses were built so most have had more brought in over the years.
Also, imo, because of the lack of topsoil, I don't get much water retention and most just runs off or dries up way too quickly.
I have areated and with previous years, through a lot of work, I have been able to maintain a decent lawn. When we moved in, this lawn, both front and back were a nightmare filled with weeds, patchy grass, burnt areas, you name it. When our Liberal Gov'T banned weed and bug killer, that is when things started going south on me. Plus, with the purchase of our trailer and still working, the time I use to spend maintaining it definitely fell to the wayside.
I also believe I have chinch bugs and I know I have grubs as well. I just sprayed with some bug killer my neighbor allowed me to use so hopefully when I get those under control, I can start this lawn on its road to recovery.
As suggested, I'll likely just start bringing in a yard or 2 of topsoil/compost each spring and fall to only add a little bit at a time.
I also forgot about sheep manure. I have heard that works really well.
My back lawn, which gets a lot of shade and actually looks like it has topsoil, has done really well. I cut it 2-3 times more than I do my front lawn, and yes, I do have my mower raised pretty good.
Thanks for the tips so far guys. I guess I just have to decide what soil product would work best on this lawn then take it from there. I also need to find a more hearty, drought resistant seed that I know exists.
cheers
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4837274
08/11/18 12:19 PM
08/11/18 12:19 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
Have had exactly that done professionally in the last year. Here's what was done:
[*]de-thatched
[*]power aerated
[*]about an inch of best quality soil added as top dressing
[*]grass seed raked in
[*]rolled
[*]watered once or twice daily for at least 2 weeks
[*]no mowing until the grass was well up, whipper snipped only early on, later mowed with a freshly sharpened blade at a high setting
[/list]
That worked quite well.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4837290
08/11/18 12:44 PM
08/11/18 12:44 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Seek out the wisdom of local experts regarding seed choice, etc.: http://www.guelphturfgrass.ca/factsheets ...In our climate, I prefer a good blend of bluegrass,fescue,and rye species that are specific to your local conditions. Blends tend to be more resistant to disease, drought, etc. and require less input (fertilizer, etc.) vs. pure bluegrass.
This site from one of the premier turfgrass programs in the U.S. should also have suitable, similar climate advice: https://www.canr.msu.edu/home_lawns/
Re: Top soil, triple mix or something else for top dressing lawn [Re: irv] #4837349
08/11/18 01:50 PM
08/11/18 01:50 PM
ecotourist Offline
ecotourist  Offline
If your lawn is 30' X 25', you have 750 sq ft to cover. To add 1 inch (1/12 = .0833') you'd need 750 X .0833 = 62.5 cu ft of topsoil. With 27 cu ft per cubic yard, you'd need (62.5/27 =) 2.3 yards of topsoil.
But an inch is probably too much (it might kill the grass you already have), so depending on how many hollows you have to fill, and how much topsoil you want to retain or use elsewhere, 1 or 2 yards (as you suggested originally) would be about right.
2000 BMW 528i 5MT
