2021 RAV4 Hybrid AWD hot rod
by AZjeff - 11/20/19 10:50 PM
0W30 with MB 229.52 and VW 507 for Canadians
by Snagglefoot - 11/20/19 10:12 PM
Need new Binoculars
by FirstNissan - 11/20/19 09:47 PM
Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
71 registered members (4WD, bdcardinal, AZjeff, buddylpal, BigCahuna, Blkstanger, 3 invisible), 1,367 guests, and 20 spiders.
Topics297,701
Posts5,120,957
Members69,924
Most Online3,589
Nov 2nd, 2019
Trans problem on honda harmony 1011 riding lawnmower, won't go in gear #483654 05/22/04 03:29 AM
H
HOndaGuy Offline OP
H
The message says it all guys. I started cutting my grass today, and all of a sudden, the transmission wouldn't go in gear at all. Im wondering if the transmission is shot. Any suggestions?
Re: Trans problem on honda harmony 1011 riding lawnmower, won't go in gear #483655 05/22/04 06:11 AM
Chris142 Offline
I'd look at the thing closley. Most small engines and transmissions use set screws to hold the gears to the shaft. Maybe one came loose.
Re: Trans problem on honda harmony 1011 riding lawnmower, won't go in gear #483656 05/26/04 06:25 AM
Propflux01 Offline
I am not too familiar with that type of mower,but if it is the type with replaceable fluid (I.E. A Tranny with a drain plug) check the fluid first, if it got low or leaked out somehow, it wont shift.
Re: Trans problem on honda harmony 1011 riding lawnmower, won't go in gear #483657 05/26/04 04:39 PM
B
Bror Jace Offline
B
Also make sure that the switch under the seat didn't get knocked into neutral.
I switch mine into neutral to push it around the garage floor sometimes, then forget and wonder what's "wrong" with my tractor and why it completely lost its drive. [Embarrassed]
--- Bror Jace
