Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
New Fave way to remove snow from vehicles
by JC1 - 11/12/19 08:19 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
23 registered members (Bailes1992, carlprop, Char Baby, FT92, berniedd, BillyE, 3 invisible), 951 guests, and 17 spiders.
Topics297,340
Posts5,113,454
Members69,840
Most Online3,589
Nov 2nd, 2019
OCI For track car? #4836238 08/10/18 08:36 AM
Spetz Offline OP
Hi guys,
I have a car I use only for the race track (circuit).
The engine is a 6A12 from a Mitsubishi FTO.
I run 5w40 Shell Helix Ultra in it.
It has been close to 1 year since it's had the current oil in it.
In this year it did about 300 miles (most of which close to redline) and has been warmed up maybe 20-30 times.
What should my OCI be?
Annual?
Should I change oil filter too?
2003 Mitsubishi Diamante 6G74. 165k miles.
Penrite HPR10 10W50, 12K km OCI
UOA:
https://www.bobistheoilguy.com/foru...ante-shu-5w40-1-2-can-mos2-7-8k-mile-oci
Re: OCI For track car? [Re: Spetz] #4836255 08/10/18 08:52 AM
B
BMWTurboDzl Offline
B
UOA's would help you decide the proper interval.
If the car is used for racing only, I would use a race oil since the add pack would be optimized for those conditions.
435i
Re: OCI For track car? [Re: Spetz] #4836266 08/10/18 08:59 AM
F
FermeLaPorte Offline
F
What does Mitsu recommend on those engines when racing? I would look for that and maybe start planning it out.
Re: OCI For track car? [Re: Spetz] #4836279 08/10/18 09:19 AM
skyactiv Offline
Subaru says something crazy for those auto crossing. New oil for the event and change it afterwards.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: OCI For track car? [Re: Spetz] #4836323 08/10/18 10:18 AM
A
A_Harman Offline
A
Can you tell us more about the engine and environment?
Turbocharged or naturally aspirated?
Approx HP?
Maximum revs on track?
Does it have an oil cooler? Max oil temperature and where measured?
Is there an Accusump (pressure accumulator) in the oil system?
When I was running my Camaro on track, I just depended on the oil monitor to tell me when to change, and the engine survived just fine on various high quality synthetic 5w30's for 16 years.
If you are just doing track work with the engine, a series of UOA's over event weekends would eventually give you a picture of viscosity stability, fuel dilution, oxidation, and wear metal trends. Just starting out, I recommend an oil sample after each event, and after 3 such events trends can begin to be established.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: OCI For track car? [Re: Spetz] #4836331 08/10/18 10:24 AM
B
BrocLuno Offline
B
Yeah, it's all about the UOA's. Understand that you hate the expense and leaving the oil in, but it's the best way smile
Re: OCI For track car? [Re: BrocLuno] #4836449 08/10/18 12:38 PM
CT8 Offline
+1 if you want to know !
Re: OCI For track car? [Re: Spetz] #4836692 08/10/18 05:54 PM
Spetz Offline OP
Thanks everyone.
I do a time attack against myself, so not competitive racing.
I have a temp gauge on a oil filter sandwich plate and so far max temps were 110c (230f).
The engine is mostly standard (NA) but has some bolts ons and ported heads that give about a 15% increase (230ish hp at the crank).
Cutout rpm are 8,200 but about 8,000rpm is what it sees on the track.
I do warm up and cool down laps.
15-20 min track time per hour and i generally do slow laps in that time to give the car a break
I'll look into a UOA
UOA:
