Caliper piston replacement.
by LeakySeals. 02/16/19 11:30 AM
Speed Bleeders - Used Them?
by john_pifer. 02/16/19 11:19 AM
4EAT Subaru
by HowAboutThis. 02/16/19 10:38 AM
delete
by beanoil. 02/16/19 10:37 AM
First oil change
by Bill_W. 02/16/19 10:18 AM
Mobil M1-110A
by Purpfox. 02/16/19 10:17 AM
Oil recommendation for 2018 titan 4x2
by Ttown. 02/16/19 10:10 AM
M1 filters?
by dogememe. 02/16/19 09:44 AM
Granatelli Indy 500 and STP :)
by shanneba. 02/16/19 08:01 AM
2010 Chevy Corvette, Castrol GTX Magnatec 5w30
by montero1. 02/16/19 07:22 AM
veloster wheels on my sonata
by JustinH. 02/16/19 07:05 AM
Beast chewing on garage door seal
by LeakySeals. 02/16/19 03:01 AM
Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
krzyq, Huberthagans, 3dfever, Mahmoud, Happycamper
67248 Registered Users
98 registered members (240_Ed, ABerns, Astro_Guy, 4WD, 15 invisible), 2,223 guests, and 49 spiders.
Topics298,272
Posts4,988,469
Members67,248
Most Online2,474
Feb 10th, 2019
Peak tutoral on radiator flushing is WRONG #4835889
08/09/18 08:15 PM
08/09/18 08:15 PM
missouri
ragtoplvr Offline OP
missouri
Here it is
https://peakauto.com/diy-hub/antifreeze/
After the cleaner there are 3 plain water flushes. So the system is 100% water at this point. Draining the radiator leaves a lot of pure water in the system. Then they filled it with 50 % pre-diluted coolant, resulting in a weak mix. Very weak. Will freeze and not have proper coolant protection.
the proper procedure is read the owners manual for cooling system capacity. If it 18 quarts, divide by 2 to get 9 quarts. This is how much pure coolant you add. If you can not get that much in, then you drain the overflow tank and fill it with the balance.
Inexcusable.
And the contact us link on the peak site does not work.
Rod
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835894
08/09/18 08:21 PM
08/09/18 08:21 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
That is why I refuse to use 50/50. Maybe on a newer car just doing a drain and fill with factory coolant but that’s it. I just did a distilled water flush on the Buick. I made sure not to buy 50/50 dexcool. By the way, I contacted valvoline about their Asian coolants only being 50/50. They said it was fine to flush and use 50/50 even though there is pure water in the block. I just told them I wouldn’t be purchasing their antifreeze. They also told me I could use dexcool in my Mazda.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835902
08/09/18 08:29 PM
08/09/18 08:29 PM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
When I flush the radiator on my truck I do the same with doing the rinses with tap water. I add 50/50 coolant that I diluted myself. After I run the engine for a trip to town and back the leftover water and antifreeze is mixed. When I test the concentration it shows over 50% concentration.
I blame that on a faulty tester but point is it's not weak, plus if memory serves correctly a 50/50 mix is good to -35 F.
Think twice, speak once.
Re: Peak tutoral on radiator flushing is WRONG [Re: SVTCobra] #4835912
08/09/18 08:38 PM
08/09/18 08:38 PM
missouri
missouri
this can not be true unless ALL the flush water drained out. I suppose there are cars where that happens, I have never owned one. Your description violates the laws of physics, and no one does that.
Sorry. Either you did a poor flush, or you have weak antifreeze.
Rod
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835923
08/09/18 08:44 PM
08/09/18 08:44 PM
The land of USA-made Subies!
SubieRubyRoo Offline
When I flush the Subaru, I pull the thermostat housing. Since it's conveniently located on the very bottom of the engine, it is nearly a complete drain. Then 50/50 antifreeze ends up really close to 50/50. It's a great design.
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835937
08/09/18 09:02 PM
08/09/18 09:02 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
My customers don't understand this at all. They refuse to buy pure antifreeze,they only buy 50/50 which they add to the existing water and end up with only 25% antifreeze.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Peak tutoral on radiator flushing is WRONG [Re: Chris142] #4835943
08/09/18 09:12 PM
08/09/18 09:12 PM
missouri
missouri
well, the bright side is you get to replace a lot of parts in the winter.
Rod
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835947
08/09/18 09:14 PM
08/09/18 09:14 PM
USA
oldhp Offline
oldhp  Offline
USA
Flush, drain, add 1 gal pure anti-freeze. Top off with 50/50. Never had a problem and always 20-30 below zero.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835953
08/09/18 09:24 PM
08/09/18 09:24 PM
out there
spasm3 Offline
spasm3  Offline
out there
On the second flush or third flush i measure how much i have to add to get the system filled. Subtract that from the published capacity and you know how much remains after draining. Then you know how much straight coolant to add to get to 50/50.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4835961
08/09/18 09:37 PM
08/09/18 09:37 PM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
Rod
Most popular vehicle sold in the US is the Ford F-150. My owners manual for my 03 says the coolant capacity is around 25 quarts. When I changed it years ago, I used just shy of 4 gallons, so 19 quarts, leaving 5 quarts of water in the block after the flush. Half of 19 is 9.5 plus 5 quarts of water left over gives a 58/42 water/coolant mix.
According to a chart for Zerex G-05 a 40% coolant concentration is good to -15 F. I've had it colder than that and don't have a problem.
Re: Peak tutoral on radiator flushing is WRONG [Re: SVTCobra] #4835964
08/09/18 09:41 PM
08/09/18 09:41 PM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
Just shy of 4 gallons would be about 15 quarts, leaving 10 quarts (2.5 gallons) of water.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4836052
08/10/18 04:53 AM
08/10/18 04:53 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
For simple rad d&f, should have stopped before adding the cleaner, just filled using the 50/50 mix. Once he added the cleaner and circulated, full strength AF then required and as noted fill to half system capacity with AF and top with distilled. I likely would have used distilled water for complete flush series, at least last two flushes. Looks like Joe Thomas needs someone to inform him why his procedure is incorrect, and Peak should take it down.
As for contact, don't know about now but in past always been responsive to my inquiries using that contact method.
Re: Peak tutoral on radiator flushing is WRONG [Re: Sayjac] #4836091
08/10/18 06:03 AM
08/10/18 06:03 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
To Sayjac: You said, "As for contact, don't know about now but in past always been responsive to my inquiries using that contact method."
You're right but the OP's communication wasn't in the "page of responses" given to the monkey to reference. Also, since his communication was a criticism/correction he probably erased it to avoid being the bearer of bad news.
Re: Peak tutoral on radiator flushing is WRONG [Re: ragtoplvr] #4836117
08/10/18 06:39 AM
08/10/18 06:39 AM
Glendale, Arizona
billt460 Online content
billt460  Online Content
Glendale, Arizona
My biggest argument with 50/50 premix antifreeze, is it's a total rip off when compared to the full concentrate. I can't believe anyone would be foolish enough to buy it. But they line up to. 50/50 premix of standard Prestone runs $8.88 at Wal-Mart. While the 100% concentrate is only $10.87. Or just $1.99 more for twice as much pure antifreeze.
https://www.walmart.com/ip/Prestone-Extended-Life-Prediluted-Antifreeze-Coolant/16879961
https://www.walmart.com/ip/Prestone-Extended-Life-Antifreeze-Coolant-1-Gallon/16879960
Re: Peak tutoral on radiator flushing is WRONG [Re: billt460] #4836203
08/10/18 07:58 AM
08/10/18 07:58 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Never seen 100% here and I doubt its available.
Moderated by  ekpolk
