There are videos on Youtube on B&S lawnmowers running on some crazy stuff in the crank case. One even ran with sand in there for quite a while. They were trying to kill it. The put sand in the carberator and everything to finally kill it.
Any 30-40 oil wt be it 0w 5w or 10W should fine. I personally run 5W30 penzoil platinum because I can get it at the nearly the same price as conventional. It is also the oil I run in my truck.
