Originally Posted By: ZeeOSix
Originally Posted By: Trav
Does the efficiency of the platinum increase over time?
According to research by Purolator/Mann+Hummel, oil filters usually don't get more efficient with loading. As the filter loads up, the increasing delta-p causes some of the captured debris to continually shed. The way the ISO efficiency test is ran, the resulting efficiency number is the average efficiency measured from new to near fully loaded. That means a filter with a low ISO efficiency is probably a bigger shedder with delta-p (on top of inefficient media capturing performance) than a filter with high efficiency.
I guess engines that use no oil filters and only screens like the old bug engines should have torn themselves to pieces in no time but in fact bearing and crank wear was not a real issue with them it was crank end play issues and jug wear from heat as they were getting on in life from being air cooled not a lube failure.
Those old VW Bugs were lucky to hit 100k miles without a rebuild. The ones that lasted the longest had very frequent oil changes. Aftermarket oil filter kits came out for them for a reason. Jug wear was probably more due to extreme oil temps around the ring pack due to bad jug air cooling, and oil with not enough HTHS and anti-wear performance to keep the ring & cylinder wear under control.
You still don't address the fact that main and rod bearing were was not any more of an issue than engines with oil filters.
Most engines of that era were well worn or worn out at 100K oil filter or not, I know for a fact I learned my trade in that era.
Jug wear was universally bad on all engines in those days water and air cooled, so bad in fact they made in the car boring bars (not hones) for cylinder reboring.
Why did water cooled engines with filters have so many bearing failures? The oil in that era was garbage that's why, people putting filters on old bugs were convinced by marketing they needed to installed one pretty much like they put catch cans on today.
I had a 66 bug that had no filter and it ran perfectly fine, with very little wear as shown by the couple of UOA's I did long before UOA's were popular.
Why is it that when people do UOA's and higher than normal silicon is found wear PPM is usually increased? Why didn't the oil filter high efficiency or otherwise catch it? The first suspect is always unfiltered air ingress due to a leaking filter housing or leaking PCV system.
Hey I have nothing against FU, platinum or any oil filter that doesn't tear, they are all doing something but IMHO they end result of one over the other is way overblown with the exception of diesels which produce an enormous amount of soot and carbon that really foul the oil badly very quickly.
Most engine damaging particles are below 16 micron so those particles are going right past the FU also with its 20 micron 99% rating also. For the most damaging steel particles a magnet is much much more efficient than a full flow filter.
http://ecomicrofilters.com/whareclpacs.html
I am not going through this whole business with you again, leave it at that, other posters can draw their own conclusions.
