Originally Posted By: JC1
Maybe it's a good idea to keep a second "Clean" filter for quick swaps. Once swapped out you can clean it within the first week before it gets dirty again.
Love it! Change when you need and clean when you can.
With your conditions that bad, no problem cleaning...as mentioned knock out the loose stuff and shop vac. I'd stay away from high pressure air to make sure you don't put a hole in the media.
