Originally Posted By: Virtus_Probi
Originally Posted By: vwmaniaman
I hope you have good soldering skills. The computer boards are multilayer and have copper traces between the board layers. Sometimes it is best to just get the cap off and leave the leads sticking out of the board and wrap the new caps legs on the leftover leads and solder that.
To be honest, I would try something like this.
I was good at soldering for a couple of years, but my skills have faded from lack of use...even at my best, though, I would have tried hard to mess with the board as little as possible and make use of the old leads. Or maybe just solder a more modern surface mount ceramic cap across the leads, although that might be risky as the ESR of the electrolytics may have been contributing a zero that actually improved the stability of the nodes they were sitting on.
I thought about this a little more and trying a modern low ESR ceramic is probably a bad idea here.
It would probably be fine for looking at something in a lab like I would be doing, but not for something you want to work flawlessly for years. I would be happy if a board I used in the lab would stand up to a few months of abuse, and anything that wasn't soldered down on the board was almost disposable (I went through many dozens of LEDs when I was evaluating one my parts, couldn't easily get ones rated for the max output current of the part so I massively overdrove smaller ones and they tended to melt!).
Stick with using caps of the same value and type as the old ones!!
