The Sled has a small coolant leak on the passenger side oil cooler line fitting just a bit below the upper coolant hose. It appears to be weeping from the joint with the end tank.
Indy said to use Bar's Leaks Radiator Stop Leak Concentrate. I used about half a bottle. It leaked less for awhile, then began leaking more. However it's still a SMALL leak. I keep a regular eye on it as the hood is opened every day in the evening to dump the heat. I add about half-a-cup once a week.
I've heard some talk about the tablets rather than the liquid. Are they preferred?
