Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
Saab 9-3 Carrier Bolts - 155 ft lbs
by ET16. 06/17/19 09:15 AM
Fran CA11480
by jcartwright99. 06/17/19 08:43 AM
Recommend oil for 2020 Kia Soul 2.0L
by Hoot_r. 06/17/19 08:40 AM
Why does Amsoil market the way it does?
by Redright9. 06/17/19 08:36 AM
'11 CTSV - M1EP 10w30 - 8K Built LSA - ~2k sample
by oilnoob32. 06/17/19 08:34 AM
Blue smoke and Mobil 1 Syn High Milage!!
by Kestor. 06/17/19 08:03 AM
crank and water pump pulleys stuck
by slybunda. 06/17/19 07:50 AM
2018 Mazda6 oil choice?
by gabriel9766. 06/17/19 07:33 AM
The Real Scoop
by RayCJ. 06/17/19 06:08 AM
time based timing belt change question
by berniedd. 06/17/19 03:18 AM
Vtwin rod bearings with synthetic oil
by kawie_guy. 06/17/19 02:25 AM
BG MOA is now LSPI "safe"
by The Critic. 06/17/19 12:42 AM
Skraeling, Metalmanx48, Cannedcreamcorn, Kestor, Slipcase
68418 Registered Users
97 registered members (alphadog, AC1DD, 2012AccentSE, 53' Stude, 87sammy, ad244, 12 invisible), 2,327 guests, and 23 spiders.
Topics290,573
Posts4,988,691
Members68,418
Most Online2,967
Mar 10th, 2019
2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan #4825966
07/29/18 06:18 PM
07/29/18 06:18 PM
Maine, USA
Minorgroove Offline OP
Maine, USA
Just did a drain and fill at 30K miles on my 2.7L Ecoboost 4x4 with the 6R80 transmission and STOP/START feature. I reused the filter as I wanted to get a look at it since it is different than the typical 6R80 and has 2 outlets on the top side of the filter. I will try to buy a new filter for my change at 60K.
When I dropped the pan, I was shocked to see 2 magnets in the pan as opposed to the standard single magnet. I assume this was a mistake during assembly since there isn't a second dimple in the pan to locate the additional magnet. After cleaning the pan and magnets, I put them both back the way I found them. The second magnet wasn't interfering with anything and both had a thin gray layer on them...figuring two magnets are better than one at clearing metallic fragments. Refilled with about 7 quarts of Mercon LV and seems to be working fine.
Has anyone else found additional magnets in their transmission pan before?
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4825993
07/29/18 06:40 PM
07/29/18 06:40 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
Back in the 70's Ford plugged the dipstick hole with a plastic plug. The assembly guys were supposed to pull the plug out when they installed the dipstick. Most just shoved the plug on through and into the pan.
A few years later someone pulls the pan and finds the plug. Goes into a panic trying to figure out where it came from.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Chris142] #4825997
07/29/18 06:45 PM
07/29/18 06:45 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
I had an 04 F150 and I found a red plastic plug in the pan on the first change...I called my Uncle who owns a shop and he said the same thing you did. He said he still finds them on occasion even on "newer" trucks.
As for 2 magnets OP i have no idea. If it doesnt hit anything it wont hurt to have it in there IMO.
2008 Silverado Z71 LT 96k Maxlife FS 5w30
2010 Ford Escape 192k QSUD 5w20
2016 Yamaha XSR900 13k, Spectro 10w40, Yamaha Filter.
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Chris142] #4826002
07/29/18 06:51 PM
07/29/18 06:51 PM
Maine, USA
Maine, USA
Yeah, I remember working on a friends 2004 F150 and found that plastic plug in the trans pan, they had clearly been doing that for decades. I had seen a few descriptions online so it wasn't a surprise. I can imagine how that would freak someone out though!
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4826021
07/29/18 07:20 PM
07/29/18 07:20 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I had 2 magnets in my 2015 2.7 F150
2015 F150 2.7
2018 F350 6.2
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: CT8] #4826028
07/29/18 07:34 PM
07/29/18 07:34 PM
Maine, USA
Maine, USA
So, if it happened to your 2.7L as well, either they are quite sloppy on the line or somebody is doing this on purpose. Maybe it's not a flaw, but a feature!
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4826061
07/29/18 08:10 PM
07/29/18 08:10 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
The magnets are different sizes, maybe it's intentional. The first pan drop i did on a Pinto i found that goofy plug. It was a little puzzling.....
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4826086
07/29/18 08:37 PM
07/29/18 08:37 PM
southwest Mo.
wtd Offline
wtd  Offline
southwest Mo.
In less than 2,000 miles, I will be changing fluid in my 2014 Mustang GT with that transmission. I expect to see only one magnet.
Any tips on getting a proper fluid level since this tranny has a thermostat that controls the fluid flow or did you just refill with the amount that you took out.
I do plan on changing my filter.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4826092
07/29/18 08:46 PM
07/29/18 08:46 PM
WV
loneryder Offline
loneryder  Offline
WV
It looks like the magnets are supposed to go in those 2 squares in the pan??
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Chris142] #4826159
07/29/18 10:30 PM
07/29/18 10:30 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
I average about 3 calls a year for this.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4826197
07/29/18 11:52 PM
07/29/18 11:52 PM
USA
Bob69 Offline
Bob69  Offline
USA
This may have been covered elsewhere; but does anyone in this thead have a solid opinion
on adding a strong magnet to the outside of the pan?
My thinking is to put a strong magnet near the drain plug, then a few seconds before removing the drain plug, remove the magnet, then do a drain and fill. Seems like the flow of the old ATF out the drain hole should bring some of that magnetic dust with it?? Then put the magnet back in the same place after done changing the oil and before starting the engine.
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: loneryder] #4826275
07/30/18 06:05 AM
07/30/18 06:05 AM
Maine, USA
Maine, USA
No, those bumps in the squares at the front of the pan make contact with the bottom of the filter. There is a specific place at the center/rear of the pan for the magnet with a raised dimple to center the magnet and some small outer dimples to keep it in place. The second magnet was just off to the side past the filter, so it seems out of the way and shouldn't interfere with anything.
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Bob69] #4826278
07/30/18 06:12 AM
07/30/18 06:12 AM
Maine, USA
Maine, USA
I wish my pan had a drain plug to make removing the fluid from the pan easier. The magnets were covered in a gray film of metallic goo, but the inside of the pan itself had a very light gray film as well. I guess the magnet helps to magnetize the entire pan. I am glad I dropped the pan to clean it out, but I guess an external magnet like you described could work. Just draining the pan after removing the magnet would remove much of the gray goo, but it still might be worth dropping the pan to wipe it out just to be sure.
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: wtd] #4826281
07/30/18 06:29 AM
07/30/18 06:29 AM
Maine, USA
Maine, USA
After reinstalling and torquing the pan bolts (98 in lbs), I filled with about 5 quarts until a bit overflowed from the opening and started it up to idle in park. Checking the little dip stick while it was running showed that it was barely registering on the bottom. So, I added one more quart while it was still running and checked again. It was now about half-way up the stick. This let me know that about one more quart would get me close. My dip stick had two marks, a hatched section labelled A, and a checked section labelled B. This was a bit confusing until I found the image below showing that it is supposed to get to the top of section B when at full operating temperature (206-215 degrees F). Mine was at the top of A/bottom of B while the transmission was near 100 degrees F. After running a while, the temp went up to about 120 degrees F and the fluid level started rising into section B. Given the expansion rate of the fluid when it was heating, this should get me to the top of section B when fully hot. I couldn't get it any hotter idling in my garage and I didn't feel like taking it on the road to heat everything up and then get it all back lifted up to check again.
Re: 2016 F150 6R80 30K Miles - Found 2 Magnets in Trans Pan [Re: Minorgroove] #4826282
07/30/18 06:30 AM
07/30/18 06:30 AM
New York
pbm Offline
pbm  Offline
New York
I think the 2 magnets are a feature rather than a mistake.
When I had a Buick I intentionally installed a 2nd magnet in the transmission pan....I had it laying around from the Magnafine I had taken off my Corolla.
'Journalism is Dead'
