The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
best way to buy a new vehicle?
by WhyMe. 01/15/19 11:07 PM
Cat Humor
by StevieC. 01/15/19 11:06 PM
Lightning McQueen (Humor)
by StevieC. 01/15/19 11:04 PM
Fastest Land Mammal (Humor)
by StevieC. 01/15/19 11:01 PM
Wifes says decorate the baby's room (Humor)
by StevieC. 01/15/19 11:00 PM
Taco Bell (Humor)
by StevieC. 01/15/19 10:57 PM
Van full of money (Humor)
by StevieC. 01/15/19 10:56 PM
Amazon Packaging (Humor)
by StevieC. 01/15/19 10:55 PM
Star Spangled Banner in school (Humor)
by StevieC. 01/15/19 10:52 PM
Maybe on to something? (Batman Humor)
by StevieC. 01/15/19 10:49 PM
Canadian Breakfast (Humor)
by StevieC. 01/15/19 10:48 PM
Tinder Anyone? (Humor)
by StevieC. 01/15/19 10:45 PM
(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
36 registered members (4WD, Astro14, billt460, alcyon, Black_Thunder, anndel, 3 invisible), 903 guests, and 38 spiders.
Topics296,627
Posts4,955,927
Members66,950
Most Online2,577
Jan 14th, 2019
Page 2 of 2 1 2
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: tempnexus] #4811545
07/11/18 03:36 PM
07/11/18 03:36 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Biotech is ester-based, and yes, Lubegard was very responsive (as much as can be expected without divulging secrets) when I contacted them.
I have a VOA of Lubegard Heavy Duty Engine Protectant (identical to Biotech) in the VOA section. LG confirms the formulae are identical in emails in the thread.
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: Rand] #4811555
07/11/18 03:45 PM
07/11/18 03:45 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Originally Posted By: Rand
I would just use a full syn dexos 1 gen 2,HTO-6 oil
Pennzoil platinum ticks all those boxes(and more)is $22.xx at walmart for 5qts and
there is a 10$ rebate--new rebate starting july.
I see no need to water it down with additives.
Agreed!
"If I walked on water, they'd say I couldn't swim."
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: 123Saab] #4811579
07/11/18 04:22 PM
07/11/18 04:22 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Originally Posted By: 123Saab
Originally Posted By: Zee09
Why not call or shoot both companies an email? You'll get the answer straight from the horse's mouth, vs. a lot of opinions. I had good luck asking the LG people questions.
Do you use it demar?
Yes, I have used Biotech Engine Protectant, and MoS2. After seeing pictures Trav posted from his oil pan drop I stopped using MoS2. In vehicles that sit for long periods of time, a few weeks or more it falls out of suspension and collects in the bottom of the oil pan. His pictures and some discussion he and I had was reason enough to stop using it.
I thought it was Ceratec that fell out of suspension?
Both for Trav. Ceratec in an air compressor motor and MoS2 in his car engine.
God Bless Our Troops
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: turtlevette] #4811581
07/11/18 04:23 PM
07/11/18 04:23 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Can we get a link to that discussion?
I'll shoot him a message. Maybe he has it book marked.
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: tempnexus] #4811603
07/11/18 04:46 PM
07/11/18 04:46 PM
NM
tempnexus Offline OP
NM
Contacted both companies will post response once I get it.
Thank you all
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: Zee09] #4811635
07/11/18 05:29 PM
07/11/18 05:29 PM
New England
gathermewool Offline
New England
Now, I don't want anything in my oil. Just good solid oil! Thanks.
I prefer liquid oils for my vehicles, personally.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: turtlevette] #4811824
07/11/18 08:40 PM
07/11/18 08:40 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I found it: https://www.bobistheoilguy.com/forums/ub...lat/fpart/8/q/1
Here's the picture of the oil pan, and his observations:
Originally Posted By: Trav
I used Ceratec in a compressor not an engine that was MoS2. I could see the Ceratec in the sight glass so I pulled the side cover and cleaned it out and changed the oil.
The stuff in the oil pan I found when I changed the rusted pan otherwise I would have had no idea it had fallen out.
The greenish grey stuff is MoS2 and no it did not mix back into the oil when the engine ran, the engine ran 2 hrs before the pan drop, the oil was still warm. The chunks are pieces of gasket from the tube that got knocked in taking it off.
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: tempnexus] #4813213
07/13/18 12:53 PM
07/13/18 12:53 PM
NM
NM
Below you will find the answers regarding this topic from the respective companies mentioned in this thread.
Code:
thank you very much for contacting us and your interest in our LIQUI MOLY products.
The MoS2 particles in our MoS2 Anti-Friction Engine Treatment are temperature resistant up to more than 800°F - so much more temperature resistant than any motor oil and its additives is.
Deposits in the oil supply lines of / in the turbo charger is a common problem, caused often by the use of not suitable motor oils and / or stop-start systems.
To avoid deposdits inside the oil circle we recommend you to use #LM2037 Pro-Line Engine Flush before the oil change. Carbon deposits inside the motor oil system (e.g. piston ring zone and oil supply lines to the turbo charger) are dissolved and held in suspense so that they´ll be drained out with the used oil. The engine is cleaned up and ready for the fresh oil which stays fresh longer now. The life of the turbo is extended and the oil consumption reduced to the maximum. We recommend to do a Engine Flush every approx. 20K miles.
Engine Flush is just a "soap" that softens existing deposits inside the oil system and keeps the softened deposits in the oil in a solution. When draining out the used oil you also drain out the deposits. Now the engine is free of disturbing deposits and ready for the fresh oil.
- Add #LM20002 Cera Tec into the fresh oil (dosage approx. 6-7% of the total oil volume). Cera Tec is our latest formulation for maximum engine protection - proven in high performance engines worldwide.
Once added into the motor oil the chemical surface protection lasts up to 30K miles. So we recommend to add it at every 2nd or 3rd oil change and you can interchange with our #LM2009 MoS2 Anti-Friction Engine Treatment which is a solid lubricant which mainly reduces the friction force between the moving parts inside the engine.
Please let us know the exact vehicle data of your Volvo (engine / year / total mileage) to recommend you the suitable LIQUI MOLY motor oil, too.
Please find the product and application information.
We hope we could help you with our information. Should you have further questions regarding our products we would be very pleased to get contacted from you again.
Best regards
i. A. Steffen Niemietz
Anwendungstechniker
application engineer
F & E / Anwendungstechnik
Phone:        +49 731 1420-658
Mobil:        +49 162 2815064
Fax:        +49 731 1420-44658
[email protected]
LIQUI MOLY GmbH
Jerg-Wieland-Straße 4 | 89081 Ulm | GERMANY
www.liqui-moly.de
Amtsgericht Ulm HRB 1383 | Geschäftsführer: Ernst Prost, Günter Hiermaier
Court of registration Ulm, HRB 1383 | Managing Director: Ernst Prost, Günter Hiermaier
Es handelt sich bei dieser E-Mail um keinen Spam. Wir informieren Sie im Rahmen unserer Geschäftsbeziehung über Preise und Aktionen. Sollten Sie solche Informationen nicht wünschen, richten Sie Ihren formlosen Widerruf an: [email protected]
This is no spam email. In the context of our business relation we inform you about our prices and promotions. If you do not want to receive such information, please send your informal revocation to: [email protected]
LIQUI MOLY ist Deutschlands beliebteste Motorenöl-Marke!
LIQUI MOLY is Germany´s most popular motor oil brand!
Code:
Lubegard Bio-Tech Engine Oil Protectant is synthetic and fully compatible
with Castrol Edge Synthetic 5w30. Lubegard was designed specifically for
high temperature applications such as turbos with oil coking being an issue.
You will also enjoy the enhanced lubricity that tends to smooth out idle and
in general quiet down the engine. Generally, coking can be reduced by
allowing the turbo to cool at bit by idling for a minute before shutting
down the engine. It's been a standard procedure with turbo diesel
applications for the last 20 years and will work well for gasoline engines
with turbos too.
Please let me know if I can do anything else.
Best regards,
Pat Burrow
Technical Director
Stellar Automotive Group | International Lubricants Inc.
Seattle, WA
Office: (206) 762-5343 x 14
Toll Free: (800) 333-5823
www.Stellargroupinc.com www.Lubegard.com
facebook.com/Lubegard  |    twitter.com/Lubegard  |  youtube.com/Lubegard
Re: Would MOS2 or Lubegard Biotech coke up on Turbo? [Re: tempnexus] #4823536
07/26/18 10:40 AM
07/26/18 10:40 AM
USA
RDMgr Offline
RDMgr  Offline
USA
By definition, coke is a carbon based deposit. Mineral oils, PAOs and esters can coke. MoS2 contains no carbon. It might form a deposit but not coke.
Page 2 of 2 1 2
