Hi guys, and gals
Bought an Escape with a bad motor last year. I bought a replacement engine from a wrecking yard with 55K miles not long after. Because the motor is about 13 years old, I will be replacing front and rear seals, and pan gasket, maybe valve covers for sure. Then I started thinking maybe pull the timing cover and check/replace timing chains, maybe replace valve stems seals, maybe replace head gaskets.....thinking crazy thoughts I know.
I figure the engine will be a nightmare to work on the timing cover while it is in the car in the future. The valve cover needs to come off to remove timing cover. The wrecking yard pulled the pan to inspect it for putting it up for sale. So that would need to be done at a absolute minimum. The engine with the pan off looks real clean inside, the coolant that came out of the motor looked clean as well.
I still have not removed the old motor. So I have a lot to do. I'm pretty capable, but I'm trying to rationalize the best course of action without tearing the engine totally down.
Looking for objective opinions Thanks Pat
2nd picture is a Vulcan motor, not a Duratech
Link:
http://www.tomorrowstechnician.com/engine-series-a-decade-of-the-duratec-30/
Link:
