Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
106 registered members (apollo18, 2015_PSD, agarb, 4WD, 2010Civic, 87sammy, 13 invisible), 2,333 guests, and 43 spiders.
Topics305,921
Posts5,282,802
Members71,537
Porsche 75w90 #4820250 07/22/18 08:51 AM
dgjks6 Offline OP
I bought 5 quarts of Porsche 75w90 diff fluid about 3 years ago. Sold the car and havebeen staring at the fluid for the last 3 years. According to the bottle it expired in 2017 and was made in 2015. I don't put much stock in that since the service interval fof the fluid in the diff is 12 years or 120,000 miles.
Anyway, I have a ford excursion and want to swap out the front diff fluid. It calls for a 75w90 GL 5
Can I use the Porsche stuff in it? I don't know what the GL rating of it is or where to find it.
Re: Porsche 75w90 [Re: dgjks6] #4820252 07/22/18 08:57 AM
4WD Online Confused
Online Confused
Check the other brand name applications for the Porsche … I’m seeing GL4 in some …
Re: Porsche 75w90 [Re: dgjks6] #4820269 07/22/18 09:14 AM
R
Reddy45 Offline
R
Should be fine. I actually went the opposite direction and bought a bunch of Delvac 75w90 to use in my Tacoma’s diffs. The Delvac is a popular choice among the Porsche crowd since it doesn’t have LS additives in the formula.
Re: Porsche 75w90 [Re: Reddy45] #4820291 07/22/18 09:29 AM
4WD Online Confused
Online Confused
When you say “bunch”? Did you get one of the (Delvac 1) 4 jug deals … seems to save about $10/gallon like that …
Re: Porsche 75w90 [Re: 4WD] #4820299 07/22/18 09:36 AM
R
Reddy45 Offline
R
Not THAT good of a deal. Summit racing sells each jug for around $32 which is literally half the price of Amazon and WM. I bought a few jugs to cover my next 2 diff/xfer case changes.
Re: Porsche 75w90 [Re: dgjks6] #4820324 07/22/18 10:20 AM
rooflessVW Offline
Is it the Porsche transaxle oil or differential oil? If it's transaxle oil I'd put it on Craigslist or eBay. Someone will give you almost what you paid, I'm sure. Then buy cheaper and more appropriate oil for your differentials.
If it's differential oil as intended for the Cayenne or Panamera differentials, you'll be fine.
"Zed's dead baby, Zed's dead."
Re: Porsche 75w90 [Re: dgjks6] #4820325 07/22/18 10:24 AM
B
bmwtechguy Offline
B
What model and year Porsche? We can look up the spec for the Porsche and see if it also meets the spec for Ford (GL5). But the 75W-90 part seems to be correct for the front diff on your Ford. For the rear diff on the Excursion, I would use 75W-140.
Re: Porsche 75w90 [Re: Reddy45] #4820334 07/22/18 10:35 AM
4WD Online Confused
Online Confused
Thanks for the tip … got a jug of Delvac 1 75w90 for that price … and a set of AC Delco iridium plugs to get free shipping …
Re: Porsche 75w90 [Re: dgjks6] #4820442 07/22/18 01:41 PM
Chris142 Offline
One would think that if its good enough for a Porsche its good enough for a ford.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Porsche 75w90 [Re: Chris142] #4820449 07/22/18 01:48 PM
4WD Online Confused
Online Confused
I’m waiting for Ford to know what’s good for Ford … 150k for normal … 30k for “severe” ?
(Don’t get folks started on PSD oils) hide
Re: Porsche 75w90 [Re: dgjks6] #4820450 07/22/18 01:50 PM
dgjks6 Offline OP
It was for the manual trans of a 1999 911
It is Porsche 75w90
That’s all the bottle says
Re: Porsche 75w90 [Re: dgjks6] #4820476 07/22/18 02:35 PM
rooflessVW Offline
It is Porsche 75w90
It's not necessarily unsuitable - but it's probably $150 worth of oil - not what I'd use in a common differential.
Re: Porsche 75w90 [Re: rooflessVW] #4820602 07/22/18 05:01 PM
dgjks6 Offline OP
It “expired” in 2017. So even if it is good in your Porsche for 12 years tonthem it is worthless. It’s is $40/liter now. I paid $117 which including shipping when I bought it. I tried to sell it on the Porsche forums a couple times. No luck. So I’m either at recycle it or use it up
