Anybody know how to make this? I've got all the stuff to do it.
Very quickly:
1/2 gallon of milk + 1 cup instant milk
4 oz yogurt
1) Heat the milk in the microwave until it boils, or reaches at least 180°F
2) Pour the mixture into a non-metallic dish and wait until it reaches approximately 120°F
3) Stir in the yogurt (room temperature) and cover (towel) in a warm place for 8 hours
Notes out of making several batches:
Not heating the milk to at least 180°F will not allow the yogurt to set later. It has something to do with denaturing the proteins in the milk. Boiling doesn't hurt. 2% or whole will make the yogurt creamier, but will work if you make it with 1% or even skim. 120°F is with my thermometer and produces consistent results.
Thickening the yogurt can be accomplished by adding a small amount of instant milk to soak up the extra whey, and/or allowing it to set longer than 8 hours. I've done up to 12, which makes it noticeably thicker. The temperature in the first hour is the most critical. After 10 hours, the mixture should be very thick and have a tangy, bubbly surface you can test out. Move it to the refrigerator and it should stay fresh for at least a week or two if you keep it covered and don't cross-contaminate spoons when you're removing it from the container.
Washing every utensil and dish with hot, soapy water and drying thoroughly beforehand is very important in avoiding contamination. I use a small crock pot to make the yogurt in, and it keeps the temperature at a good region for the bacteria to grow. I also turn the oven on for about 5 minutes before it goes to sleep.
I usually go for plain, but with the funkiest mix of bacteria. A single-serving container will set a whole batch (up to a gallon). I've used cheaper store-bought yogurts and they don't work as well. BB-12 and LA-5 are beneficial cultures, but there are quite a few you can get a hold of if you read the back of different brands. I've also seen kits that are specifically made for making your own.
Very quickly:
4 oz yogurt
