I plan on doing one of these https://www.tundratalk.net/forums/mainte...uid-change.html
some say I will get 4 qts with pan drain some 2-3 qts, not sure till I drain pan. But if I add same amount as I drain back to fill plug, start truck and let same amount drain out cooler line into bucket, shut off truck and repeat till old fluid is out. There is no risk of pump running dry, or damage to trans, whether it is 4 qts vs 2 qts done at a time, correct?
